Crossmember opening diameter?
Old May 11, 2006 | 12:31 PM
CoolKars's Avatar
CoolKars
Default Crossmember opening diameter?
I have a 1970 4 speed. I am out of town and need to know the exact diameter of the crossmember openings to order some parts.
Thank you in advance.
Old May 11, 2006 | 10:02 PM
CoolKars's Avatar
CoolKars
Anyone have exact measurement of crossmember opening. Would really appreciate, so I may purchase some parts while out of town. Thanks again!
Old May 11, 2006 | 10:21 PM
TonySinclair's Avatar
TonySinclair
Don't have my car in front of me, but...if it helps...I have 2 1/2" pipes and, IIRC, there's about 3/4" left surrounding the pipe. I believe other members have fit 3" pipes thru the crossmember.
Old May 11, 2006 | 10:28 PM
CoolKars's Avatar
CoolKars
Thanks Tony. I am looking to use v-band clamps like 632C2 did on C2,don't know if C2 & C3 are the same. I believe flanges have an OD of 3 1/4" need to know for sure if flanges will fit through openings.
Old May 11, 2006 | 11:05 PM
TonySinclair
Sorry, can't be of more help. Car is locked away for the night. I'm sure someone will chime in soon. The forum covers lots o' time zones.
Old May 11, 2006 | 11:57 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Saw your thread earlier. Had the 78SA up on the lift so I measured it. 3 1/2".
Mike
Old May 12, 2006 | 01:55 AM
CoolKars's Avatar
CoolKars
Thanks Mike for your assistance and time while 78SA was on lift, hope it was just for routine maintenance.
To Crossmember opening diameter?
