Carb question?
Old May 13, 2006 | 03:51 AM
Rydin Dirty's Avatar
Rydin Dirty
Default Carb question?
i have a 1978 corvette with the original rochester carb in it. im still trying to figure out how to set the choke on it cause im having a lot of problems with it. i got it set but it runs at like 1800-2000 rpms when i start the car. it doesnt turn off until temperatures hit 150-160. the setting that i have it at is higher than what is marked on the choke markers. from the center i turned it to so the screw driver is facing perfectly straight up. to make it easier to understand if u turned a screw the flat head screw would be straight like this (|). i live in florida so its going to work a lot differenly on my car than most around the country. especially with the fact that i am at 5 feet above sea level. thats about the only problem i have with my choke is that it runs so damn long with it on.
keith
Old May 13, 2006 | 07:18 AM
a1sensei's Avatar
a1sensei
Manual choke will stop the pain! God bless, Sensei
Old May 13, 2006 | 08:21 AM
Rydin Dirty
I think we went over this once before if im not mistaken . i was thinkin about doing that but.... i just want to get what i have working properly. nothing against what u said but i just want to get this thing going the way it should be. I thank u sensei. By the way its great meeting everyone again from DC over here !!!
keith
Old May 15, 2006 | 01:00 PM
Rich's'78's Avatar
Rich's'78
I believe you have a "hot air" choke. the carb pulls a bit of air over the coil from a steel tube that dips into your intake at the heat crossover. if the carb choke hole is plugged, the tube is missing/broken so that you don't pull this warmed air over the coil it will take a full warmup to come off fast idle. it is easy to switch to an electric choke - get a kit from Summit, etc.
Old May 15, 2006 | 01:09 PM
woody1's Avatar
woody1
I concur on the switch to manual
Old May 15, 2006 | 01:53 PM
lars's Avatar
lars
I can't think of a single good reason to switch the '78 choke system over to a manual system. The '78 hot air choke is an excellent choke system that works very well. If your idle speed is too high, just lower it to the spec speed. If the choke is staying on too long, adjust it. If you need instructions, drop me an e-mail request for my choke setup paper.
V8FastCars@msn.com
To Carb question?
