4 SPDS MUNCIE SIDE COVER REMOVAL?
Old Aug 23, 2001 | 10:15 PM
Ki m Le's Avatar
Ki m Le
Default 4 SPDS MUNCIE SIDE COVER REMOVAL?
I need to replace the oil seals for the shift shafts. The service manual specifies to put it in second gear, before remove the cover. I assume the transmission must be in neutral first! Is it correct?
Thanks for any feedback.
Old Aug 23, 2001 | 10:50 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Default Re: 4 SPDS MUNCIE SIDE COVER REMOVAL? (Ki m Le)
I think the only reason to put it in second may be so the shift forks easily clear the case....don't really think it matters it will come off regardless... :smash:
