Rad hose collapsing
Old May 13, 2006 | 08:16 PM
nptwoody's Avatar
nptwoody
Default Rad hose collapsing
My upper hose sprung a leak yesterday and I discovered that it had a cut underneath where the fan could have nicked it. I put in a new hose and while driving today after it was warmed up I stopped and restarted the car and the upper hose collapsed causing the fan to slice another hole in the hose. I got another hose hooked it up and it too is collapsing upon shutting the car down after hitting the thermostat temp. What can cause this? thanks Jim
Old May 13, 2006 | 08:20 PM
SIXFOOTER's Avatar
SIXFOOTER
got to have air in the system somewhere. With it full of liquid it can't colapse
Old May 13, 2006 | 08:29 PM
David Ey's Avatar
David Ey
Did the origional hose have a spring inside?
Old May 13, 2006 | 08:32 PM
SIXFOOTER's Avatar
SIXFOOTER
the bottom hose has a spring since its on the suction side of the rad, but the top one doesn't
Old May 13, 2006 | 08:34 PM
David Ey's Avatar
David Ey
Oh, I see. Must be air then.
Old May 13, 2006 | 08:42 PM
2th farmer's Avatar
2th farmer
CI 6-8-9 Veteran
Slowly release the cap when the hose is collapsed and see if in re-inflates. A bad cap can cause it.
Old May 13, 2006 | 08:48 PM
nptwoody's Avatar
nptwoody
will try your advice in the morning, if it inflates i will move on to the next suggestion and try to "burp" the rad and get the air out. thanks will let you know how it goes.
Old May 13, 2006 | 08:50 PM
VetteLS6's Avatar
VetteLS6
Old May 13, 2006 | 09:21 PM
jdmick's Avatar
jdmick
Sounds to me like the little valve in the cap that allows fluid back into the radiator from the recovery tank is stuck shut. A new cap should fix the problem.
Old May 14, 2006 | 10:57 AM
Mike Ward's Avatar
Mike Ward
Sounds like you have the wrong radiator cap. The correct one will allow air or fluid to be sucked back in when the motor cools down.
To Rad hose collapsing
