What's the difference...?
Old May 13, 2006 | 11:14 PM
TonySinclair's Avatar
TonySinclair
Default What's the difference...?
Between an "L-88" hood and a "big block" hood? I always assumed they were the same until reading something recently indicating otherwise.
Need something to cover-up my pending TPI swap...
Old May 13, 2006 | 11:25 PM
Jclgodale3's Avatar
Jclgodale3
Big Block/Lt1 hood blends into the hood at the back edge (no opening). An L88 hood is taller at the back and is open for fresh air.
Old May 13, 2006 | 11:27 PM
TonySinclair
Do they look similar? e.g. L88 = big block hood with a bigger "hump"?
Old May 14, 2006 | 12:12 AM
jerrylee's Avatar
jerrylee
hey tony..check out my profile...i have a good pix of my bb hood...
Old May 14, 2006 | 12:33 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
My sig pic has the L-88. Much higher than a BB/LT-1 hood. Was there a BB hood in '74?
Old May 14, 2006 | 12:44 AM
TonySinclair
Is that a GM BB hood or just a hi-rise hood? I don't recall having seen that hood in a stock set-up.
Old May 14, 2006 | 12:46 AM
TonySinclair
I believe the 454 fit under the stock (SB) hood in '74. My TPI probably won't, so I'll need something taller. I'm also installing L88 light covers and sidepipes, so the taller hood won't look too out-of-place on my '74.
Old May 14, 2006 | 12:49 AM
TonySinclair
OK...I think I got it:
LT-1 "BB" hood:
L88 "BB" hood:
Old May 14, 2006 | 12:51 AM
zwede's Avatar
zwede
L-88 gives you about 2" more room than the LT1/BB hood.
Old May 14, 2006 | 12:53 AM
TonySinclair
How much more room does the LT1 hood give you over stock? I don't think I'll need too much to fit my TPI.
Old May 14, 2006 | 01:05 AM
Star79's Avatar
Star79
The difference is:
L-88 hood questions go in Tech/Perf
BB hood questions go in Gen
Although the mention of a TPI swap might be enough to keep this one in Tech
Old May 14, 2006 | 01:11 AM
TonySinclair
Old May 14, 2006 | 01:26 AM
Star79's Avatar
Star79
Trying to be funny. Sorry, been a long day
Old May 14, 2006 | 01:47 AM
TonySinclair
Alllllrighty then...must be some of that "Canadian" humor...
Old May 14, 2006 | 02:27 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
He's a lumberjack and he's OK...
Old May 14, 2006 | 08:06 AM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
This is a BB hood.
Old May 14, 2006 | 12:40 PM
jerrylee's Avatar
jerrylee
Tony 2 be honest with you I don't know.She was on there when Ipurchased my car.................
To What's the difference...?
Old May 14, 2006 | 12:50 PM
PRNDL's Avatar
PRNDL
obviously, the L-88 hood was only used in 68 and 69 with the L-88 option. The bigblock hood was used in 68 -72. To the experienced eye there is a big and obvious difference. Perhaps the most obvious difference, aside from the height difference is the 2 chrome inserts used on the bigblock hood. I believe the 73 and 74 bigblock cars used the same hood as the smallblock cars.
Tony, what year do you have? With aftermarket hoods you have to consider whether you have a wiper door (68-72) or not.
Old May 14, 2006 | 01:02 PM
Bangkok Dean's Avatar
Bangkok Dean
Heavy wood
Old May 14, 2006 | 03:30 PM
TonySinclair
Yes, '73 & '74 used the "small block" hood, regardless of the motor.
My car is a '74. I believe Vanacor makes both the L-88 and LT-1 hoods in the later-model "long" version to fit my car.
