huge weight saving
Old May 14, 2006 | 12:19 PM
Bangkok Dean's Avatar
Bangkok Dean
TT are you planning to run a heavy pressure plate, and do you think the clutch petal will be Strong enough for some heavy shifting?
Old May 14, 2006 | 12:44 PM
panic's Avatar
panic
Originally Posted by Twin_Turbo
carbon pedals
you must be joking
Old May 14, 2006 | 12:47 PM
Twin_Turbo's Avatar
Twin_Turbo
Right now I have LT5 clutch equipment and it's a hydraulic clutch. The pedals are sgtrong enough, the tab that bolts them to the pedal rod is off center so you push directly on the rod, not on the side of the pedal which could lead to them breaking
Old May 14, 2006 | 12:57 PM
Bangkok Dean
TT on to A heavier question. I have with many others on this forum been following your progress. With all the mods you have done and plan to do what will the difference in weight be from stock to your finished weight?
Old May 14, 2006 | 01:06 PM
Twin_Turbo's Avatar
Twin_Turbo
I don't know what the difference will be, I hope a lot. I seriously am trying to get below 3000 lbs. A stock 82 weighs about 3350 lbs
Old May 14, 2006 | 01:47 PM
mrvette's Avatar
mrvette
I would like to think I lost some 300 lbs overall on my car, but, in truth I have never weighed it recently....
I would like to get some cheap stock type aluminum calipers/master cyl and then weigh in...and then mentally subtract 50 lbs for the purported weight ditching this 700 auto for the 200 auto....
GENE
Old May 14, 2006 | 02:27 PM
norvalwilhelm's Avatar
norvalwilhelm
Mine weighs 3500 with a bigblock and blower. I do weigh it yearly.
Old May 14, 2006 | 02:29 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Im going to weight mine soon. Im hoping to be around 3000 but It will probally not be.
Old May 14, 2006 | 02:40 PM
groovyjay's Avatar
groovyjay
I like those pedals TT, I'm using lots of carbonfiber on my current project and those pedals would be a nice addition...
I went with Sparco's alu pedals in the C3-R, no real weight saving, but on the looks department I think they are a huge improvement plus they are bit narrower, which suites me better!
Old May 14, 2006 | 03:15 PM
PRNDL's Avatar
PRNDL
dang groovy! Those things remind me of bicycle pedals! They do look a little slippery tho.
Old May 14, 2006 | 03:16 PM
groovyjay's Avatar
groovyjay
they actually have much better grip than the old worn out ones...
Old May 14, 2006 | 03:27 PM
Twin_Turbo's Avatar
Twin_Turbo
Jay, what are you using for carbon fiber parts? I have (partially) carbon fiber intercoolers, brake ducting, oil cooler ducting, the pedals and a catch can.
Old May 14, 2006 | 03:43 PM
  #33
enkeivette's Avatar
enkeivette
Originally Posted by turtlevette
we're just teasing you because we like you. There is not much we can tell you that you don't alrready know so we give you smart as comments instead. You know your are appreciated here.
And I'm sure getting rid of all the little stuff when you had the body off the frame will make a huge difference. It's all the little stuff that adds up, i.e. speakers, head unit, computer, wiring, switches, sensors, antenna motor, charcoal canister, spare tire stuff, cruise control, AC stuff etc. Also you cut off that huge vacuum canister for the headlights in front of the car didn't you?
Old May 14, 2006 | 03:55 PM
  #34
Twin_Turbo's Avatar
Twin_Turbo
The 80-82 cars don't have a large vac can, they have a small container that looks like a bean can botled to the front, it's very light but I got rid of it. I don't even have the very heavy front frame extension anymore, just a bumper bar w/ many holes triangulated into a tubular steel frame:
Old May 14, 2006 | 04:03 PM
  #35
groovyjay's Avatar
groovyjay
Hood, doors, door panels, trunk lid, dash and some other parts here and there... I'm just making the molds and a friend of mine takes care of the actual cf part.
Old May 14, 2006 | 04:10 PM
  #36
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
What kind of car?
Old May 14, 2006 | 04:38 PM
  #37
groovyjay's Avatar
groovyjay
Originally Posted by Yellow73SB
What kind of car?
A Corvette, is there any others?
To huge weight saving
Old May 14, 2006 | 05:04 PM
  #38
Twin_Turbo's Avatar
Twin_Turbo
weird vette...trunk lid? a c5/6 ???
Old May 14, 2006 | 05:05 PM
  #39
groovyjay's Avatar
groovyjay
C2
Old May 14, 2006 | 05:08 PM
  #40
73jst4fun's Avatar
73jst4fun
As we say "good for 5 hp"
