Power Window Help
Old May 14, 2006 | 04:02 PM
YankeeStation1967's Avatar
YankeeStation1967
Default Power Window Help
pic deleted
Old May 14, 2006 | 04:25 PM
SIXFOOTER's Avatar
SIXFOOTER
wire harness in the door shorted together? Look at the connectors carefully. Looking at the schematic thats all I can think of
Old May 14, 2006 | 04:45 PM
c3dreamer's Avatar
c3dreamer
Power windows have the following components: Left and right window motors, left and right pw switches and related wiring, and a circuit breaker of 35 Amps.
1. Left window motor has two wires: one brown and other dark blue.
a. Brown cable is connected from motor to left side connector of left power window switch (up movement)
b. Left window motor have a dark blue wire connected to right connector of left power window switch (down movement)
2. Right window motor has two wires: one tan and another light blue.
a. Tan cable is connected from right power window motor to left side connector of right power window switch (up movement)
b. Right window motor have a light blue wire connected to right connector of right power window switch (down movement)
3. Both Left and Right front window switches have a third independent connection. From each connection runs a pink wire that have a common connection that runs to the WDO Circuit Breaker of 35 Amps.
4. Each motor is grounded. Circuit breaker has a hot wire all times.
Double check wires connections, grounds, breaker, motors, switches.
In some circuit breakers they must be reset manually.
Perform voltage checks, continuity checks and fuses verification.
Good luck!
Old May 14, 2006 | 06:31 PM
Ric's80_4sp's Avatar
Ric's80_4sp
These motors are grounded through the metal/frame. Run a test ground wire from the motor to a good ground source and see if this works. If it does, clean-up the metal around the attachment points with a wire brush.
ric
Old May 14, 2006 | 09:26 PM
c3dreamer's Avatar
c3dreamer
Originally Posted by Ed T
i grounded the motor to a good ground, now the window will go down & not go up by the switch..............unless i disconnect the connector to the motor & put 12v from the batt charger to the motor , then it goes up fine.
Replace the problematic switch with a new one. It do not complete the electric circuit for the up movement.
Old May 14, 2006 | 09:57 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
on my car.....it had broken right through in the middle where it bends in between the door and door jamb....i could see these breaking and touching against each other creating that situation
To Power Window Help
