No, Really I'm Bubba
Old May 16, 2006 | 12:19 PM
evalu8r's Avatar
evalu8r
Default No, Really I'm Bubba
I can't believe this happened!!!!! Of all the STUPID, MORONIC, IDIOTIC. How could I let this happen.
Here is a pic of my baby before it went in.
Here's what I found when I pulled the head. A SCREW!! WTF!!!!!!!!!
Here's the piston. Is this still usable or should I pull it?
I can't believe what I'm seeing. It just makes me want to curl up into the fetal postion in a corner and die.
Old May 16, 2006 | 12:31 PM
Bill Baird's Avatar
Bill Baird
Don't reuse the piston.
What does the cylinder wall look like?
Old May 16, 2006 | 12:34 PM
rihwoods's Avatar
rihwoods
Stuff happens...think I would replace the piston....
evalu8r's Avatar
evalu8r
Walls a perfect.
Old May 16, 2006 | 12:35 PM
Danishbanker's Avatar
Danishbanker
Any idea what happend??
Old May 16, 2006 | 12:40 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Wow..really sorry to see that. If it were me I would replace the piston and disassemble, clean and replace rings and bearings on the entire bottom end....you might also want to think about farming it out...In my younger day's I assemebled a few engines and they never seemed to last very long...I will always go pro build in the future...
Hauq`'s Avatar
Hauq`
You shouldn’t use that piston. It looks like the screw punched through at the quench; you should check the rod to make sure it didn’t bend. Also check the bore if it’s all torn up you may have to punch it out to .040.
Good luck, I feel for you.
Old May 16, 2006 | 12:41 PM
bashcraft's Avatar
bashcraft
Looks like a screw went through it.
jimmygmartin's Avatar
jimmygmartin
If you replace the piston you should also rebalance. I think you could reuse it if you clean up the damage with some emory cloth, get rid of all sharp edges. Not ideal but will save you alot of work & $$.
Old May 16, 2006 | 12:42 PM
68 NJConv 454's Avatar
68 NJConv 454
As long as piston walls are perfect with no grooves then I would replace the piston and head.
If you know how th screw/bolt got in there then just live and learn.
If you don't then I would look into it to avoid a repeat incident.
Good luck
Old May 16, 2006 | 01:45 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
see how the plenum is left uncovered... thats all it takes screw gets dropped in while doing something else .....
and you see the results..
really sorry to see that man. dont take it to hard... could have bee a bigger bolt
Old May 16, 2006 | 01:48 PM
Black 82's Avatar
Black 82
Looks like a carb stud that fell into the manifold and went through the valve.
Old May 16, 2006 | 02:16 PM
evalu8r's Avatar
evalu8r
Ding Ding Ding Ding. You win the prize. Is that guess from experience?
Old May 16, 2006 | 02:21 PM
Black 82's Avatar
Black 82
No. But I once had a wrist pin retainer fly off the pliers, across the garage and straight into the crank case of my Harley engine. I couldn't find the retainer anywhere on the floor so on a hunch I stuck a magnetic retreiver in the crank case. There it was. I couldn't have tossed it in there if I tried. Crisis averted.
Old May 16, 2006 | 02:26 PM
sweethence's Avatar
sweethence
I was swapping an intake once, got it all bolted up, was putting the coil braket on the intake ( before i put the carb on) had to walk away..... somehow lost the other bolt to the braket oh well got plenty o spares right
guess where it dropped
Old May 16, 2006 | 02:48 PM
Red70vette's Avatar
Red70vette
If you were really a Bubba you would patch it up with JB weld and bolt it back together and then sell it to me.
All the while smiling and figuring that it is fixed properly and I will never know the difference.
When I found out and threatened to beat you to within an inch of your life you would reply "What is your problem? I have done that many times and there was never a problem. I use JB weld and super glue to fix everything."
Old May 16, 2006 | 03:10 PM
evalu8r's Avatar
evalu8r
Okay, maybe Forest Gump then.
To No, Really I'm Bubba
Old May 16, 2006 | 03:22 PM
Boofers's Avatar
Boofers
Don't be too hard on yourself. That isn't a bubba, its a booboo.
Old May 16, 2006 | 03:35 PM
BerniesVette's Avatar
BerniesVette
Chris, I am glad that I am not alone, to ere is human so I must be super human!
Bernie
Old May 16, 2006 | 03:58 PM
TedH's Avatar
TedH
Had similar incident back around '83. Installed a rebuilt carb on my 350 in '74 Z28. Screw in carb made its way into cylinder. Destroyed the piston, bent a rod, cracked the cylinder and damaged both the rod and main bearings. Bearings, rod, piston and sleeved cylinder (#6 if I recall correctly). Had driven the car about 100 miles before the screw made its way into the cylinder then all hell broke loose. Must have been left over from the carb rebuild.
