a conundrum
Old May 17, 2006 | 11:05 PM
68 NJConv 454's Avatar
68 NJConv 454
Norval tested some spark plug extenders with an adjustable angle at the end...maybe those would do the trick to avoid hitting the headers.
http://forums.corvetteforum.com/show....php?t=1374813
Make sure your current won't jump from the plug wires to the header. Good luck
Old May 17, 2006 | 11:20 PM
84rzv500r's Avatar
84rzv500r
Originally Posted by Guru_4_hire
I am learning towards a header flange and 2 sets of header gaskets.
maybe... Flip them over so they point up weld a short stainless 90 and the turbo flange to the collector and wala...
A 4 inch hole saw and dump the exhaust through the hood. Let them turbo's peak out a little. with a totally stock looking body. It will scare the SH*T out of the ricers. A N20 bottle and a purge nozzle, just for show
Old May 18, 2006 | 12:08 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Sorry to stray off topic, but are those stock C4 exhaust manifolds with A.I.R. tubes? If so, what year C4s can those be found on?
Old May 18, 2006 | 07:02 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
The earlier 80s because the later 80s went to the D shaped port 85-87 I believe
Old May 18, 2006 | 11:16 AM
kb2fzq's Avatar
kb2fzq
Just ONE plug is this way?
How could that be??
Very strange....very strange...
...and I thought I had problems in my life
Old May 18, 2006 | 03:59 PM
Guru_4_hire
Cruise-In V Veteran
the 4 center plugs right now. I havent really checked the others.
Old May 18, 2006 | 04:09 PM
Guru_4_hire
Cruise-In V Veteran
Can someone with a 12" ruler measure the distance from the heads to the steering mechanism, and from the exhaust down to the motor mount.
Old May 18, 2006 | 04:34 PM
69autoXr's Avatar
69autoXr
Later C4's (86+) had angle plug heads, so what you really need are manifolds off a later car. If that is you are bound and determined to use C4 manifolds.
Are those heads not D-ports?
Old May 18, 2006 | 05:05 PM
82Vette'ster's Avatar
82Vette'ster
....distance from the heads to the steering mechanism, and from the exhaust down to the motor mount....
If the other clearances will let you, you could machine the flange at an angle to make the bottom kick out. That with short plugs, a little dent, and a band of header wrap to protect the boot. Might work.
Old May 18, 2006 | 06:55 PM
Guru_4_hire
Cruise-In V Veteran
These are for angle plug heads. Early L98s had square port exhaust ports, later heads have the D-port
Old May 18, 2006 | 06:56 PM
Guru_4_hire
Cruise-In V Veteran
I thought about it and you wouldnt be able to get the bolt holes to line up.
