Electrical Issue
Old May 17, 2006 | 11:28 PM
dvhammer77's Avatar
dvhammer77
1st Gear
Default Electrical Issue
I have 1979 L-82 with some electrical problems
Things that don't work
Headlights
sidemarkers
Signals (blinkers and hazards)
Brakes (only one)
tach and speedo
dash lights
heather/air
things that do work
Starter
oil, temp, volts and gas gauge
windshield wipers
I have replaced all the fuses.
Many people have suggested checking the grounds but I have no idea where to look. At this point, I am happy with getting the blinkers and headlights to work so I can drive the car.
Any help where I can find all the grounds of the car would be extremely helpful.
Thanks for you help.
Dan
Old May 18, 2006 | 08:12 AM
Boofers's Avatar
Boofers
Thats a lot of problems. Do you know how to use a voltmeter (DVM)?
Have you checked that your light bulbs are good?
Old May 18, 2006 | 09:49 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the '79 assembly instruction manual (AIM). It will show you all the grounding points for the wiring harnesses. Unless I miss my guess, the one you're looking for is on the driver's door hinge post. Difficult to see and get to with the dash installed.
To Electrical Issue
