Engine loading up at idle
Old May 18, 2006 | 04:25 PM
1996Z15's Avatar
1996Z15
Default Engine loading up at idle
What would cause an engine to load up? I noticed my car starts to load up when it sits at idle for any length of time.
The car hasn't been driven for quite a while and I'm wondering if that might have something to do with it.
I added some of that Berryman's fuel additive to the tank hoping it might remove any moisture or deposits from the tank / carburetor.
Any thoughts?
Old May 18, 2006 | 05:34 PM
Little Mouse's Avatar
Little Mouse
maybe the needle and seat is not cutting off the fuel in the primary
bowl and is stuck.
Old May 18, 2006 | 06:08 PM
1996Z15's Avatar
1996Z15
bowl and is stuck.
Do you think there's any chance of the fuel additive I put in the fuel tank freeing this condition up or do I need to have the carb looked at?
Old May 18, 2006 | 06:29 PM
Little Mouse
if its a holley lightly tap on the float adjustment on the primary bowl
this may free it up. Take a wrench an keep lightly tapping it or the
wood end of a hammer. Light taps.
Old May 18, 2006 | 06:58 PM
1996Z15's Avatar
1996Z15
No such luck, stock 1969 L46 with Quadrajet
Old May 18, 2006 | 10:01 PM
Little Mouse
My knowledge on Q-jets is limited to a couple rebuilds many moons
ago LOL. Maybe a master of the Q-jet will chime in.
Old May 19, 2006 | 01:32 AM
midyear1's Avatar
midyear1
Sounds like the power piston may be varnished up , and stuck in the enrichment position with the rods pulled up out of the jets , since it hasn't had any vacuum to pull it down against the spring while the car's been sitting.
Suggest you pull off the air cleaner , and spray some carb cleaner down the vent tube at the front of the carb , which is right over the power piston/rod hanger. Since the airhorn gasket is flapped over the hanger , it will probably take several good shots to get it to seep past the gasket. You can also use a stiff piece of plastic or wood rod that will fit down the vent , and LIGHTLY push down on the hanger in between shots of cleaner. If the power piston is operating freely , you will be able to feel it move down and spring back up with the engine not running.
HTH
To Engine loading up at idle
