Coil Condenser
Old May 19, 2006 | 06:37 AM
cruz-n69's Avatar
cruz-n69
Default Coil Condenser
I have a small condenser on the side of the coil on my 69 BB that is not attached to anything. Does anyone know which termial on the coil it is supposed to be attached to (+ or -)????
Thanx, guys.
Old May 19, 2006 | 10:18 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
Thanx, guys.
negative
Old May 19, 2006 | 11:04 AM
kdf1986's Avatar
kdf1986
What is the purpose of the coil?
If it is not attached to anything, and the car is running, what does it do.
Is it a noise suppressor or something to help reduce radio interference?
kdf
Old May 19, 2006 | 11:06 AM
sweethence's Avatar
sweethence
kdf
thats it exaction radio noise suppresion
they are all over the car depending on the year
voltage regulator
turn signal and hazzard flashers
etc etc
cheers
tim
Old May 19, 2006 | 12:01 PM
pws69's Avatar
pws69
Originally Posted by sweethence
negative
What makes you say that????
It is meant to filter out transients/spikes (noise) from the POWER - It should go on the +
Old May 19, 2006 | 01:54 PM
cruz-n69's Avatar
cruz-n69
Default Score is tied
OK.....so we've got one vote Positive, one vote negative......now what do I do????
Old May 19, 2006 | 01:58 PM
pws69's Avatar
pws69
Put it on the positive or your car will most likely run (if it will start) like crap....
Oh yea, mine wasn't a vote - just a fact....
Old May 19, 2006 | 03:15 PM
sweethence's Avatar
sweethence
Sorry it took me so long to respond, missed the thread in my inbox
the reason i say this is because curretn in the car flowes from Negative to positive (revers of normal dc flow) this is why if you look at the condensor on a voltage regutalor, or the the flasher or elsewhere, that are always mounted to the casing, or the brackets i.e. the ground.
i dont have my wiring diagrams handy. but I can go out to the car in the parking lot and take a pic if you like
cheers
tim
Old May 19, 2006 | 03:32 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
It might go either place. If there is a condenser under the distributor cap, then this condenser attaches to the positive side of the coil to filter out voltage ripple/noise. If the points condenser is absent from under the distributor cap, then this condenser would hook up to the negative side of the coil to protect the points from arcing.
Old May 20, 2006 | 06:50 AM
kb2fzq's Avatar
kb2fzq
If it's designed to stop radio noise, it should be on the positive side...it's just a capacitor that takes Alternate Current to ground and shouldn't effect the coil function...IMHO...just my 2 cents...
Old May 20, 2006 | 08:57 AM
Paul L's Avatar
Paul L
I vote positive. It is a capacitor for radio static suppression.
Here is another one connected to the voltage regulator.
Old May 20, 2006 | 09:01 AM
carl a's Avatar
carl a
himmmm,sounds positively negitive
Old May 21, 2006 | 09:34 AM
pws69's Avatar
pws69
cheers
tim
Well, relative to this particular capacitor you are completely wrong!
Facts:
The negative side of the coil goes to the distributor (points/condensor)
The negative side of the coil is NOT a ground.
The capacitor being discussed is a NOISE FILTER CAPACITOR
Filter capacitors are used to filter noise from SUPPLY voltage (+ on the coil) so your radio (also connected to the SUPPLY voltage +) doesn't buzz and pop.
Old May 22, 2006 | 06:42 AM
cruz-n69's Avatar
cruz-n69
Default Tribal Council
I'll go tally the votes. Once the votes are counted the result is final and the capacitor will be asked to be connected immediately.....
Sounds like it should go on the + terminal. I'll go connect 'er up and see if the beast fires up. If it does, then away we go. If it doesn't then I'll let you folks know.
Thanks for the insight and pics. I'll never disconnect it again.......
To Coil Condenser
