Intake vacuum reading...????
Old May 20, 2006 | 11:24 AM
LannyL81's Avatar
LannyL81
Default Intake vacuum reading...????
On my '81 with a mild rebuild of the engine I am measuring between 11 and 12 in Hg at idle (700rpm) this is with a Comp Cams 268H cam with 1.6 ratio roller tip rockers.
Increasing the rpm to 1500 or so and vacuum increases to about 18-20 in Hg.
Is this about correct?
Still have the computer working, EGR and AIR pump disconnected, stock exhaust.
Thanks for any insight here.
LannyL81
Old May 20, 2006 | 11:49 AM
RLS's Avatar
RLS
my 72 with a 268 idles at 13-14. I had to crank in more timing to get it to idle right with good vacum. I have 36 total with 16 initial.
Old May 20, 2006 | 09:28 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
that sounds ok how does it run? its defintely not in the " oh crap territory"
Old May 20, 2006 | 10:50 PM
bmankin's Avatar
bmankin
That's about what I'm getting with a Comp XE262.
Old May 20, 2006 | 10:58 PM
a1sensei's Avatar
a1sensei
I was womdering if the 14 lbs I was running with my XE262 was right. I feel much better now. God bless, Sensei
Old May 20, 2006 | 11:05 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Originally Posted by a1sensei
God bless, Sensei
i bet he/she doesn't care much about corvetts..
Old May 23, 2006 | 01:12 PM
Rich's'78's Avatar
Rich's'78
I have the same cam and ratio rockers and in neutral i idle at 750 rpm and 17" vacuum. But I have headers and 2.5" duals.
Old May 23, 2006 | 03:26 PM
LannyL81's Avatar
LannyL81
The car runs pretty good...starts right up, idle is low until it warms up; two -three minutes or so. Still running rich at cold start-up, but other than that, it runs good.
It just does not run GREAT like I think it should. I was expecting more performance with this rebuild. Still checking everything out, which is why I put the vacuum gauge on it...want it to see if I had a vacuum leak. And it seems that I might have a small one yet as the reading I got is a bit low compared to the response above.
I have checked the intake bolts, carb bolts...all are tight.....should I try the carb cleaner spray around the intake to heads joint for a leak?
Thanks,
LannyL81
Old May 23, 2006 | 03:53 PM
sperkins's Avatar
sperkins
Low vacuum readings at idle can also be caused by poor carburetor adjustment. If i'm not mistaken, your car has the electronically controlled "feedback" carburetor--known officially as the Computer Command Control (C3). Not sure how to do any adjustments on these guys. How does your choke work?
Old May 23, 2006 | 05:52 PM
pauvil's Avatar
pauvil
don't know the specs on that cam but longer duration cams will cause low manifold vac.
Old May 23, 2006 | 07:19 PM
JPhil's Avatar
JPhil
My 350" with XE262 with 114* LSA, 1.52 rockers, 9.75:1 CR & old Q-jet shows 13" at idle and 16" at 2000 RPM. This is on a run stand, without being dialed in exactly, and at 5000+ ft altitude. Figure about an inch loss from spec for each 1000' above sea level.
John
To Intake vacuum reading...????
