Brake problems...im going nuts!
I bench bled the master before mounting it to the car.
Now when i bleed the system i get a spongy pedal,havent gotten it to be hard,then when i let the car sit awhile the pedal goes to the floor again,it was the same before i changed the master...
what tha heck is wrong? im going nuts
i have tried too bleed in order and its the same
how much air must there be to cause this??
it cant be much?
OK, no problem, got my daughter on the brake pedal and did them again.
Worked well for a few more minutes.
Well, turns out that one of my bleeder valves had a burr on the sealing surface and would not properly seal. It was allowing air into the system. I deburred it with some emory cloth, cleaned it up with some acetone, put it back in, and they now work great.
Don't know that this is your problem, but it's often the smallest things that cause the biggest headaches.
Good luck.
BTW, I think you would still follow bleed order regardless of the distribution/pressure/proportioning block.
