@^&* still wont start/run
Installed Edelbrock RPM heads and headers.
Vehicle would start, but would not continue to run, horrible idle.
Hooked up advance inductive timing light to altenator, shorts out and fries fuse link at starter.
Replaced starter harness, vehicle starts but will not continue to run.
Reset distributor rotor to #1 cylinder, vehicle will not fire.
After resetting distributor, attempted to start vehicle, upon cranking exhaust backfired once, did not start (exhaust has no pipes behind headers), vehicle cranks slowly.
Recharged battery, vehicle backfired once but did not start.
Pulled spark plugs and the plugs from cylinders 1 (black,oil fouled) 4 (black and oil fouled) 8 (slightly oil fouled) and broke plug on cylinder 7.
My question is since three plugs were oil fouled, is that indicitive of a manifold leak? Since the car wont start and run, I cant check for vacuum leaks. If a manifold leak is the cause, will I need to replace the manifold gaskets (newly installed) or do I need to retorque the bolts. I will replace the spark plugs but what is the correct equivelant to Champion R12YC plugs?
As for the feul system, I have a Edelbrock 650cfm carb with the thick Edebrock carburetor gasket that helped keep the feul from boiling (so Edelbrock says) will I need to replace that gasket too? Will I need to adjust the air/feul mixture screws since I now have 64cc heads? Please someone point me in the right direction before I place a bomb beneath the car and blow it up.
are you sure your ignition wires are indexed correctly on the distributor?
