Brodix heads
Old May 23, 2006 | 03:33 PM
682XLR8's Avatar
682XLR8
Default Brodix heads
Anyone have any experience with the Brodix IK200 heads? As per my post on the Dart heads, I'm thinking of switching to aluminum. like I probably should have done in the first place
Old May 23, 2006 | 03:59 PM
gkull's Avatar
gkull
How much more are the Race Rite 200's
Old May 23, 2006 | 04:11 PM
Little Mouse's Avatar
Little Mouse
Brodix will be my pick when it comes time for the heads, raised
runner here we come LOL
Old May 23, 2006 | 07:44 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I think my Brodix -8 Pro heads work very well....
They have 2.055" intakes and are very high quality items...
Old May 23, 2006 | 08:37 PM
norvalwilhelm's Avatar
norvalwilhelm
that might not be a good thing. While my headers fit really nice with normal exhuast ports 3 of my tubes needed modifications due to the raise port.
I also did extensive modifications to Vetters heads because the plugs ran straight into a couple of tubes.
Old May 23, 2006 | 08:41 PM
Shirley1978's Avatar
Shirley1978
have you got that thing running yet Randy?? when u gonna gimmy a ride??
Old May 23, 2006 | 08:52 PM
Little Mouse
Norval I'm collecting parts for a high rpm small block, I want
raised runners on the intake and different valve angles, brodix
makes an 18 degree head with raised intake runners that you can
use regular studes and rocker arms on called the 18X. I have
not bought any pistons or rocker arms yet and may just go
with there 12 degree head and run a shaft system, shaft system
is the only right way to do it but drags the price up. Oh well
its only money. If I still had a brain I would just build another
big block that is the easy way to make power and torque.
I still have three of the four bolt main factory blocks left over
from younger days, but sold off my big block stuff.
Old May 23, 2006 | 09:36 PM
Little Mouse
ttt
Old May 23, 2006 | 11:35 PM
682XLR8's Avatar
682XLR8
I'll give you a ride as soon as I quit screwing up and start buying the freaking right parts
Old May 23, 2006 | 11:45 PM
jdunne's Avatar
jdunne
I have the brodix track 1 heads on my 383,they are the ones that require the shaft roller/rockers,angle plug.....the raised ports meant that i needed custom long tube headers but i was getting those anyway so it didn't matter.....they are very good heads.....john
Old May 23, 2006 | 11:59 PM
682XLR8's Avatar
682XLR8
Checked out the Race-Rites, they're only another $300 more, but they have the 2.055 intake which I feel might be a little too large, as well as the 7/16 rocker studs necessitating another set of rocker arms and probably new pushrods also.
The IK series is supposed to be Brodix's "affordable" cylinder head, which at $999 a pair they certainly are! Plus they come with Brodix quality. Course, that's what I thought about the Dart's I'm sure I hooked into a bad batch(both heads were bad), maybe the guy setting the casting molds was hung over that day, at any rate I'm leery of getting more from the same batch on a direct exchange, so I'm gonna try something different
BTW Summits website says the exhaust ports are in the standard location. Are all Brodix heads raised port, or was Summits data entry tech just lazy?
Old May 24, 2006 | 09:37 AM
BOSTONCAMARO's Avatar
BOSTONCAMARO
I have Track 1s that have been ported and flowbenched 2.08 intake valves
Soon will take the first drive with them,,,,but even in the driveway, sounds great and loves RPM
Old May 24, 2006 | 10:04 AM
gkull's Avatar
gkull
2.02 is too small I had 2.055 on my 355 ci motors. The numbers you want to look at that really mater are the CFM of flow and what gasket size, because that determines what kind of manifolds or headers will fit.
When it standard location it justs mean standard headers will work. Both of my Dart Pro1 heads had .600 raised exhaust ports. I think my AFR 210's were raised @ .400
Old May 24, 2006 | 10:35 AM
Shirley1978
Old May 24, 2006 | 12:24 PM
62C1's Avatar
62C1
I put the IK200 on my race car this year after rebuilding the motor. Running an air gap intake. 1.6 roller rockers. Getting .575 lift. I have been real happy with the heads so far. Plenty of torque at autocross and road course. 11.8's in quarter.
Old May 24, 2006 | 12:54 PM
norvalwilhelm
My friend Brian/Vettr on this forum built a high dollar 383 and ran into a problem with the heads. The spark plug angle is such that a few of them run right into the header tubes with no way to install the plug nor put a wire on it.
I think Motorhead ran into this also and it requires either custom headers or like both of us did cut and reroute a few tubes.
Absolutely NO headers were available and all required custom sets or modified production ones.
I ran into this exact same problem with my bigblock heads.
Old May 24, 2006 | 01:27 PM
Little Mouse
Norval I will go with the spread port exhaust, mod the
headers tubes and make new flanges to fit the stahl pattern.
with the stahl pattern I should have no issues with the plugs.
the extra flow of the spread exhaust is worth the time to me,
You never Know about me someday these heads may have a
huffer on them and I will need any exhaust flow I can get my hands on.
you can get both heads I was talking about with the spread exhaust,
stahl pattern, Or the 18X can be had with the standard exhaust drilled
for both standard and stahl pattern. Have not checked price on stahl
headers they are probably high dollar. I may wish I had used a stronger
block for what I'm up to but I hate to have 10 to 12 grand in a small block
the crank,rods, pins, pistons will be strong.
To Brodix heads
