Can you identify this part?
Old May 23, 2006 | 07:42 PM
vettenuts's Avatar
vettenuts
Default Can you identify this part?
Have a friend with a 70 small block. He asked me to help him identify this part. He has spoke to a couple of vendor's, but they haven't been much help. Does anyone know what the part is circled in red?
Old May 23, 2006 | 09:22 PM
SIXFOOTER's Avatar
SIXFOOTER
Horn Relay I think
Old May 23, 2006 | 09:28 PM
audiec's Avatar
audiec
Could be aftermarket wiper washer pump...
Audie
Old May 23, 2006 | 09:30 PM
LittleJake's Avatar
LittleJake
Is it a starter relay ballast?
Old May 23, 2006 | 09:31 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Please tell us what it's connected to!
Old May 23, 2006 | 09:38 PM
Garson's Avatar
Garson
delay relay
Old May 23, 2006 | 10:58 PM
Garson's Avatar
Garson
a TCS delay relay (transmission control )
Old May 23, 2006 | 11:02 PM
b71vette's Avatar
b71vette
not the horn relay, it is located on the driver side fenderwell just above the vacuum cannister.
Old May 23, 2006 | 11:03 PM
JoeRags's Avatar
JoeRags
Originally Posted by SIXFOOTER
Horn Relay I think
thats NOT where my '70sb horn relay is..... it should be on the driver side inner fender.
I'll check tomorrow, but I dont think I have that... then again, we re-did all the wiring a few years back... no clue what we tore out, cause we tore it ALL out.
Old May 23, 2006 | 11:10 PM
CGGorman's Avatar
CGGorman
Take it out. If it still runs, you don't need it!
I know. Not much help. Us guys with 68s have to sit in the corner and watch everyody else have fun.
Old May 23, 2006 | 11:15 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Power Window relay
Old May 23, 2006 | 11:22 PM
Edzred72's Avatar
Edzred72
Originally Posted by Bullshark
Power Window relay
Thats ABOUT where my 72 PW relay is....
Eddie
Old May 24, 2006 | 07:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Order the assembly instruction manual (AIM); it'll be in there. It is not a horn relay; it is not a ballast resistor; it could be the power window relay.
Old May 24, 2006 | 08:59 AM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
It does look like that ....part of a emission control so that the advance on the dist won't kick in till temp is up..works off the passenger side water temp sender? (I think)
Old May 24, 2006 | 09:21 AM
1mollyd's Avatar
1mollyd
Looks alot like the relay I found in my '69 engine bay:
http://forums.corvetteforum.com/show....php?t=1260106
Only in my car it was hanging loose, over near the A/C box. I assumed it was a blower relay as Lars suggested.
Dave
Old May 24, 2006 | 03:51 PM
blackbirdpilot's Avatar
blackbirdpilot
Default Cowl Hood Flaper?
Not sure how the hood works on a Cowl inducted vettes (looks like a cowl inducted car? 73-??) But on the other chevs with the cowl hoods have an electric solinoid that operates the flaper at the back of the hood. Maybe realy for that function? Connected to the gas pedal like the th400 kick down switch. Activates the flaper when pedal is at full throttle
Old May 24, 2006 | 04:04 PM
dennis's Avatar
dennis
Absolutely positively
To Can you identify this part?
Old May 24, 2006 | 04:15 PM
GaryS's Avatar
GaryS
Here is what is on my very original 72:
Horn relay - up front near the rad
TCS timer relay - under the dash below the speaker
ballast resistor - don't have one, have a resistor wire
TCS solenoid - mounted on the carb, right side
It could be the window switch but those that I have seen have an orange wire instead of any other color.
Old May 24, 2006 | 10:24 PM
WashingtonRacer's Avatar
WashingtonRacer
I recall that relay on mine, tore it off, never did find out what it was for. I thought it was a spark noise filter or something odd like that.
i know it's not a power window relay, cause my windows still work.
Old May 25, 2006 | 10:13 AM
majic1984's Avatar
majic1984
Another vote here for TCS delay relay. The power window relay is located under the center console bezel.
