ZZ502 VS. Built 383?
EVERY C3 that raced and won LeMans had a Big Block for a reason.
you might get a hair in a corner on a normal big block, coming
out of the corner that big block will blow past your small block like
its stuck in the mud and he will have a big edge in getting around the next corner , and then be further gone from you to the next corner.
John greenwood and a lot of others did not have a small block to
get serious with they had rats. Still like small blocks they are just
a little on the weak side.
But also in the straight aways I could quickly run him down.
I do a have a good friend with a top of the line 383 , he spared no expense and the sounds comming from is motor is second to none but when it comes to playing I don't have to work at it. While he would have to downshift I can give him the jump, stay locked in high even with 308 gearing and still jsut walk away. Sure I am blown but I keep after the guys that for the money they have in their small blocks they could easily have a big block and alot more pulling power. Now adays even a 540 is easy to put together and not that expensive.
Want a 454 small block Ohio crank has them for about $6800
Adding a massive rear sway bar to my car seemed to have solved my problems with braking and turning.
I just purchased a 74 BB 4 speed. I have a ZZ502 sitting in the garage floor, stil in the crate, carb set up as the guys at scoggins dickey said they were have a lot of bad feed back on the fuel injection.
My daughter goes to med school there so I was able to pick it up on a visit, so only $7600.00.
Tell me everthing I need to do the the 74. I know HP flywheel, clutch etc. I want side pipes and headers. What brand and where to buy.
I want to go with Hyd. clutch, where to get this set up.
I will replace the rear spring and half shafts and am thinking about 275/50"s.????????????????? Oh, and and going to keep stock radiator and use the duel 11 inch spals. Unless I hear different on that. GM also sell's a complete serpitine belt system, complete wiht alt, power steering and a/c comp. It looks like it will fit??? HELP
I have a hot rodded 383. It's really a joy to drive. But when I installed a 427 ci small block it was a whole new animal. Going to a 502 or hot rodded BBC would really be fun. The cheapest way to get HP is a supercharger. Put a supercharger on a small block and no BBC is going to catch you. One of the forum members has a supercharger and a 150 spray system on his drag racing Small block Vette
Cooling is not a problem if you throw enough money at it.
I've competed off and on over the years at the "All corvette drags" at Sacramento California. Something has to be wrong with a 468 built up only doing low 12's.
The real license plate type cars N.A. who have their cars really dialed in were doing 11:70's with 383's the 396 -421 ci Vettes were about 11.50's . The 468's - 540 ci were all 10 - 11 second cars. People with power adders like N20 and supercharged or Turbos were as low as about 9-10 seconds once they got upto about 800 hp
