Removing Pass side lower dash pad help needed
I am trying to remove the map pocket and lower dash pad on my 76. There are 4 (or 3) screws along the top, 3 down the side by the pass side door and 2 which go in from the gauge cluster. OK, I've taken them all out and taken off the vent push/pull rod cover. It won't budge. I don't want to force anything. Have I missed something? Are there other screws somewhere up underneath that I need to remove?
I'm trying to get to the vent ducting. Just had my AC fixed (nice cold air), but want to seal up all the connections and check to be sure all the little doors are opening and closing right.
Thanks,
Jeff
Hope this helps.
[Modified by jerryp58, 10:32 PM 8/25/2001]
