I’m in the process of removing the OEM exhaust from my ’79. In doing so, I broke one of the studs that mount the Y-pipe to the exhaust manifolds. I tried threading two nuts and using one against the other as a jam nut to remove the stud but it looks like the break wasn’t clean enough and the threads are too distorted to thread a nut or two.
Before starting, I soaked the studs down with PB Blaster. The stud that broke is the inboard driver side stud. I can’t drill it out from above because the manifold and block are in the way. I’m afraid to grab the stud with vise grips because I don’t think it will grip tightly enough to remove the stud.
The next option I could think of would be to remove the manifold but I am reluctant to do this in fear of breaking a manifold bolt off in the head.
Hi, I found a stud remover at Sears that works realy great.I had a broken body mount stud when doing my off the frame resto and couldn,t budge it w/ heat or vise grips pb blaster cussing at it pouring beeer on it ect. weel this 25.00 set of stud removers took it right out.
I think that you've already figured out the problem and the solution.
Soaking the stud in PB blaster or Kroil will give you the best chance of removing the stud in place. I'd suggest a couple of days of treatments. You could try heat as well, but I'm not sure how much that'll help an exhaust manifold stud.
Vise grips are probably as good a tool as any to try to remove the stud. Tom's idea of the stud remover may work as well. I've had luck sometimes with an impact wrench on "gentle" against the jam nut to loosen it. Thoug, some of the stud removers are advertised as impact grade as well.h I've never tried it
Bottom line is that the stud is likely badly rusted and fused to the manifold. I've almost always found that the stud likes to shear off almost flush with the manifold. At that point, pretty much your only option is to remove the manifold, take it to a mahine shop and have it drilled out. Probably need a helicoil as well.
Of the six studs, I'm a little surprised that “only” one broke. Of course it had to be the least accessible one. The other five came off easily. My typical luck when working on cars. Nothing ever goes start to finish cleanly.
Actually, I'd take that as a good sign. If the other five came out, your chances of getting the sixth out are probably better. On my last manifold stud repair, one came out with a struggle, one I got out by drilling progresively larger holes and then tapping out the remnants and the third went to the machine shop for a helicoil. Sounds to me like you're in better shape than this.
Heat, lot's of heat. At worst it will take some temper out of the stud and then you can drill and tap it. If it were me then I'll attempt to remove the manifold so that I could put it on the work bench and get down to serious
Just to let everyone know that I bought the Craftsman stud removal tool and it worked fine (along with a 1/2" drive, 18" breaker bar). Thank you all for your input.
