82 Hood Release Question
Old May 27, 2006 | 02:34 PM
jwatty's Avatar
jwatty
Default 82 Hood Release Question
The hood on my 82 only releases only on the left (drivers) side. Need advice on easiest way to get right side to release so I can get the hood up. Any ideas on what might be wrong besides a broken cable, etc.
Old May 27, 2006 | 02:51 PM
Twin_Turbo's Avatar
Twin_Turbo
If you look in the wiper cowl just next to where the plastic grille is, there's a black plastic plug, remove that and insert a screwdriver into the hole, a bit of poking around should let you press against the latch lever and unlock it.
Old May 27, 2006 | 02:52 PM
TexasYankee's Avatar
TexasYankee
Cross-over cable likely broken.
I ended up taking mine to the guy that works on my Vette when mine broke.
Good luck!
Check out this also:
http://www.madvet.com/shop?store=1&...=236&frame=3852
Old May 27, 2006 | 03:04 PM
wombvette's Avatar
wombvette
The mounting tabs break causing it not to release on the RH side. Either repair the mounts or change the cable.
Old May 27, 2006 | 08:19 PM
jwatty's Avatar
jwatty
I must be overlooking something. I dont see a hole or knockout to put a screwdriver through on my 82 to trip the latch.
Old May 27, 2006 | 09:13 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Here’s a pic that might help you locate the hole in yours. Mine is an ’80, but it should be similar.
I had it happen once as well. Going forward, it’s best to do a little preventative maintenance, but just in case, I added a couple of small cables that I can get to from the underside..
Old May 27, 2006 | 09:59 PM
vettlibito's Avatar
vettlibito
my 76 did the same thing... and still doesnt.. I dont know for to "fix" the problem but when I need to get under the hood I pull the release. Then I lift the hood a little and slide my hand under and pull the cable to release the passenger side. I know what I need to do to fix it.. I'm not sure how to.. my cable is old and the tension on it is gone. I need to tighten it...
Old May 27, 2006 | 10:13 PM
cortru's Avatar
cortru
Just put the wipers in the upright position and you will see a plastic or rubber gromet about the size of a quarter,push it in with the screwdriver.
Old May 28, 2006 | 03:06 AM
murvette's Avatar
murvette
There are 2 ways to improve the tension if the tabs are not the problem,and the cable is good. The hood pull cable can be adjusted (small nut on a stiff wire that leads to the interior) and the hood cable has a large tab at the drivers side with different holes to use to create more tension held by a small cotter pin. good luck
Old May 28, 2006 | 11:52 AM
...Roger...'s Avatar
...Roger...
the left side releases right by cross cable.if the cross cable housing breaks it will not release.that does not mean the metal cable is broken.raise the hood up gently on the left ,slide your hand in under the hood palm down to the right of the latch and grab cable that is laying on top of distributor cover and pull gently and if your lucky and the metal cable is not broken the hood will pop on right side.Then replace it GM #473284 or ecklers #A2466.
Roger
Old May 28, 2006 | 06:18 PM
jdp6000's Avatar
jdp6000
Go to the link for how you do it
http://www.madvet.com/shop?frame=1.264.3852
jim
Old May 31, 2006 | 11:35 PM
jwatty's Avatar
jwatty
Crossover cable was broken, I had the local vette shop replace it today.... Thanks for the input..
Old Jun 1, 2006 | 08:47 AM
IrishJoker's Avatar
IrishJoker
Here's one for you ....... BUY a NEW Cable.
To 82 Hood Release Question
