Exhaust installation question
Old May 29, 2006 | 12:00 AM
Neo Fender's Avatar
Neo Fender
Default Exhaust installation question
I’m installing a dual exhaust system on my ’79. I have two pairs of pieces that I’m not sure about. One is a three-inch long piece of pipe (maybe a reducer) that is larger in diameter on one end compared to the other end. I assume this goes into the section that connects to the manifold but I’m not sure which end goes where. There’s also a doughnut gasket but I’m not sure which piece goes first (reducer, doughnut or what).
Help would be appreciated.
Old May 29, 2006 | 06:54 AM
GDaina's Avatar
GDaina
sounds like a reducer...you may not need it as the reducers are used to hook up headers to exhaust pipes.
Old May 30, 2006 | 07:10 AM
Neo Fender's Avatar
Neo Fender
This isn't like a reducer that bolts up to a collector flange. This pipe is only about 2" in diameter and has no flange.
Old May 30, 2006 | 07:31 AM
kb2fzq's Avatar
kb2fzq
I had 2 reducers with my DynoMax muffs to connect to the stock rear Y pipe, but you're putting a full dual system to the stock ram horn manifolds? Those will probably go small side on your chopped (manifold) exhaust pipe then the big side will go to the new pipes, I would think from what you've indicated...what's the I.D. of the small side of the reducer? The stock pipes are pretty small off the ram horns, that's why I had a new cross over pipe built when I put on the headers...
To Exhaust installation question
