Vacuum hose routing to light switch.
Old May 29, 2006 | 11:51 AM
jotto's Avatar
jotto
Default Vacuum hose routing to light switch.
Have just come home after a run and was admiring the engine bay lovingly as you do...just a quickey...the 2 vac hoses that disappear through the firewall behind the brake cylinder....are they the ones that go to the lightswitch and if so....would swapping them around cause any problems?
Reason I ask is that my headlights work on the over ride switch but not on the headlight switch ( raise and lower ) and I just wondered if swapping them would prove if the switch was faulty or if the lines were just crossed....TIA.
Old May 29, 2006 | 02:52 PM
carl a's Avatar
carl a
Old May 29, 2006 | 02:53 PM
carl a's Avatar
carl a
look here too good site----------------------------------------------------------------http://www.stingray.nu/bilder/vacuum.pdf
Old May 29, 2006 | 04:35 PM
jotto's Avatar
jotto
Thanks Carl, so if the two hoses were switched, ie the one that goes to the overide ( and the relays ) and the one that goes to the lightswitch ( from the manifold )...would that cure my problem or prove the switch to be faulty?....Damn I wish my Vette was in a garage out back....sadly 3 miles away so even the simplest of tasks is a PITA!
Old May 30, 2006 | 07:14 AM
cruz-n69's Avatar
cruz-n69
Default It does matter on a '69
I don't know what year your vette is, but on my 69 it does make a difference. I just replaced all the hoses and one of the problems I had was that the hoses to the light switch were reveresed. Switching them fixed the problem.
I also have the vacuum wiper door and so things may be different than your vehicle, but it doesn't take but a few minutes to switch the hoses and see if it fixes your problem.
Good luck......the vacuum system can be a royal PITA.
Old May 30, 2006 | 11:35 AM
Todbo's Avatar
Todbo
carl , your dia seems to be how to hook the headlight sys without hooking up the wiper door half of it? which is exactly what I'm going to do , no plans on the wiperdoor @ this point , but sure would be nice to have headlights pop up on command
Old May 30, 2006 | 02:55 PM
jotto's Avatar
jotto
Cruz-n69, so what was your problem? did your lights raise or lower before the switching of pipes on either the overide or the main switch OR did they not raise/lower at all?
TIA, off to work on her later.
Old May 30, 2006 | 10:54 PM
cruz-n69's Avatar
cruz-n69
Default Sorry, here's the complete story
When the hoses were reversed, I got no up, no down......nothing worked. When I switched them around up and down worked like new. I should have put that in my first reply. Sorry....
Old Jun 9, 2006 | 05:59 PM
Todbo's Avatar
Todbo
ok guys I used the dia "carl-a" posted as soon as I hooked the hose up , my headlights poped right up , light switch in off position , i tried to pull overide switches , turn headlights on , but lights stayed in up position , i finally had to unhook the hose and pull lights down by hand , any ideas ?
Old Jun 9, 2006 | 06:15 PM
StickShiftCorvette's Avatar
StickShiftCorvette
I have had my '69 since '76 and have travelled over 142,000 miles and once getting the all systems fully operational, I have only had one headlight actuator go out and the wiper parked valve give up. I don't consider that too much of a PITA!
To Vacuum hose routing to light switch.
