I'm replacing brake lines. How in the heck to you remove the retaining brackets on the frame. I can't even get a wrench on the 1/2 inch bolt to even turn the sucker. Any advice would be appreciated. Thanks! John
A tip--- when you put your new brake line on ( the one from front to back) be sure to tape the end that you have to slide in. Keeps the dirt out of the line.
Another tip: if the fittings are frozen and you have to use a torch, remove the bleeders. They really like to go BOOM if you don't and the hot fluid is rather painful.
Gotta love those custom tools, Paul.
I have a whole drawer full.
I got off and replaced all but one, which I clipped in half. When I ran the new brake line thru, I just bent the old clip into a "new" clip to hold the line. Seems to work so far. I'll fix it some day when I pull the body off.
As I recall, the brake line itself made it difficult to get to the bolt head. (Lifting the wrench over the brake line caused the wrench to hit the bottom of the floor.)
I used a dremel saw and sliced through the clamp. Then I pulled the brake line out and out of the way. Then I smashed the remains of the clamp flat. Then there was enough room to get the wrench in.
When I came time to install new bolts, clamps, brake lines, I shortened the length of some of the bolts. My stubbie bolts could be fit in the space between the frame and floorboard.
There were a couple on my car that were tough to do. It seemed could only turn them a little bit without taking the wrench off and repositioning it. The bad news is its just as hard to put them back in.
