Power Valve ?
Old May 25, 2006 | 09:11 AM
73 red vette's Avatar
73 red vette
Default Power Valve ?
hOW CAN YOU TELL IF YOU'VE BLOWN A POWER VALVE(holley 4160) I just rebuilt my carb put new valve in and had a couple small back fires and then it started running bad, thought it might be the idle adjusting screws so I got new ones and installed them, it now runs a lot better, but the exhaust burns your eyes like its running rich. The screws are only ajusted out 1 1/4 turns and I don't think it should be running rich at that adjustment.
Need a little input, thanks guys
Old May 25, 2006 | 09:12 AM
lars's Avatar
lars
Pull it out and suck on it.
Old May 25, 2006 | 09:25 AM
73 red vette
And after I'm done choking, then what do I do? Lars, what should I look for, should I be able to pull air thru it or not.
Old May 25, 2006 | 10:14 AM
Driftwood's Avatar
Driftwood
If the diaphragm is good-- it will hold vacuum when you suck on it. I found a small leak in mine this way. I tested the new one the same way and could immediately tell the difference.
Old May 25, 2006 | 10:25 AM
73 red vette
OK, which side do I suck on? the front, flat side or the side with the spring? just tried this on the old one and it don't seem to make a diff which side on the old one, which I believe is shot.
Old May 25, 2006 | 10:38 AM
gkull's Avatar
gkull
If your power valve is blown - It's very obvious. Your car will be missfiring , hickuping, and farting black smoke.
I used to carry spare power valves. Tunnel rams and single planes are are easy to back fire and blow out the power valves on starting if you don't pump the gas a few times to wet everything down.
Just last year on my Demon carb I had one go bad and my vette couldn't hardly get out of my driveway to go down the street.
For 6 bucks I don't suck on gas covered items.
Old May 25, 2006 | 09:25 PM
birdsmith's Avatar
birdsmith
Default Yup
Your power valve will be spring loaded to one side (open). If the diaphragm is ruptured you wont be able to close it very easily by sucking on it. And judging by what you've already mentioned about instantly beginning to run crappy after backfiring, you blew your power valve. Holley Achille's heel. Also be careful retightening the new one....you can munch the gasket and it'll leak and act just like you blew the new valve
Old May 25, 2006 | 09:48 PM
enkeivette's Avatar
enkeivette
Yeah, suck on the flat side. It should move the back of it towards you compressing the spring, it just moves a little bit, feel for it with your finger.
Sounds like a problem that I had with my Demon. Turned out that my squirters were too big and my PV spring was too stiff so it acted like it was blown, always open. I had 6-7 inches of vacuum and my PV was a 6.5. Changed the 31 squirters to 28s and the 6.5PV to a 4.5PV. Works great now. New carbs have had PV blowout protection for awhile, I doubt that your PV is blown.
Old May 25, 2006 | 10:05 PM
VetteLS6's Avatar
VetteLS6
ahh lose the PWR Valve put in a block out plug and up the jet sizes 3-6 and away you go.
Old May 26, 2006 | 08:57 AM
73 red vette
My carb is an old 4160(3310-2), if that will work I'll try it. When you say up the jet sizes 3-6 do you mean 3 to 6 sizes, I've got the jet assortment so I could try that and see what happens. I put new Idle ajusting screws in thinking that they could be worn, when I rebuilt it I drilled the holes in the primary plates thinking that might help and it did somewhat.
It had a 1" spacer block under it and I removed it also.
By the way, what psi should a DP be reading? Mine reads about 7 to 9 psi, I've read that it shoud be about 5.5 but it never says if that is for a DP or a single.
Old May 26, 2006 | 09:01 AM
GruntyPants's Avatar
GruntyPants
Holy crap! I have to make this my new sig line:
"For 6 bucks I don't suck on gas covered items."
-Gkull
Awesome.
Old May 26, 2006 | 09:30 PM
VetteLS6's Avatar
VetteLS6
Yes 3-6 jet sizes.....5-7 PSI pressure would get the job done.
Old May 27, 2006 | 09:26 AM
73 red vette
THANKS, will try the jet changes, also may try the block off plyg to eliminate the PV.
Old May 27, 2006 | 06:59 PM
enkeivette's Avatar
enkeivette
Booo... do it right. Keep the PV. Assuming that your carb is the same as mine the PV is a very good thing. It keeps you lean at cruise for good fuel economy and opens only when you need it to. Which is why the jets are so much larger on the secondary side (where there is no PV) than they are on the primary side (where there is a PV). It's a compensation thing. But there's no need to waste all of that fuel all of the time. Get a vacuum guage and screw with the squirter nozzles before you block off the PV. IMO.
Old May 30, 2006 | 04:00 PM
Driftwood's Avatar
Driftwood
I agree to keep the PV. As long as you have a decent differential between your idle/cruising vacuum and your acceleration vacuum-- why not use it as intended? I think sometimes people read about removed PVs on racing engines (with their racing cams and low vacuum) and assume they should do it to their stock engines as well.
Old May 30, 2006 | 04:21 PM
rihwoods's Avatar
rihwoods
Backfires can blister the power valve...I'd put a new one in as stated above...
Rich
To Power Valve ?
