C4 guy has C3 questions. Any help?
I'm presently doing a bit of wrenching on a C3 (1981) that doesn't belong to me. Hoping for a bit of help with a few questions:
1. I heard a brake noise when driving the car, and yanked the rear wheel to have a look. Whoever was last into the rear brakes on this car left a caliper pin out. This resulted in the pads dropping down until they contacted something that made them stop dropping. In the case of the outer pad, this something was the hat section of the rotor. Over time, the backing plate of the pad has cut a nice groove in the hat section of the rotor. The groove mics out at around .055 deep. How much meat is there in the hat section of these rotors? Does this groove present any danger of rotor failure on a street-driven car? Images below:
2. What's the lug nut torque spec on a set of these wheels on an '81?:
3. What is the bracket that appears in the center of this photo? There's one on the left side of this car, and provision to attach one on the right side, but no bracket on the right side:
Many thanks in advance for any assistance.
Be well,
SJW
looks factory it goes up and looks like it is stuck in some rubber, someone
with an 81 will chime in. Dont know how thick the metal is on the hat, I think you
should play it safe and replace it.
Be well,
SJW
While inspecting this car over the weekend, I observed quite a few things in the brake system that should be attended to in the not-too-distant future, and I'd prefer to tear into it all as one project, and for a variety of reasons, this week just isn't the time for that.
The hard line connection to this particular caliper is crusty enough that I'm skeptical it'll break free cleanly (I already leaned on it pretty hard with a line wrench, and it didn't budge), so I'm probably looking at line replacement, too.
The caliper also has a broken-off bleeder screw, so it'll need a caliper before it can ever be bled again. Which means it probably should just have all four calipers replaced w/ stainless-lined, as the condition of the others is also questionable.
Obviously, one of the pads now also has a nice little arc cut into it from abrading against the rotor hat, so the rear pads should be replaced, too.
I think you're getting the idea here...
Be well,
SJW
I presume the "tow brackets" were factory installed to prevent damage if the vehicle was towed from the rear with a sling-type tow truck like those I drove 25 years ago? If so, I think I'll just forget about the missing bracket on the other side, as this car's gonna ride a roll-back if it needs to hitch a ride nowadays...
Thanks again for the knowledge.
Be well,
SJW
Thanks much for sharing the knowledge. Gotta love this forum.
Be well,
SJW
Torque specs are as noted. Probably okay to drive like that. They are pretty thick and that wear is minimal. Tow brackets. Hmmm. I didn't know that. I thought they might be some kind of impact deflector to shove things under the gas tank in case of a rearer or something. Most brackets I have seen on C3's feel kind of flexie - but they are mounted on the bumper so that would be normal. I know a guy who bolted a trailer hitch to his - go figure
Donvorryboutthem.(Hey - - can I post here with my C3 pics??)
I'm not sure I would even do that.
Yah, I think the rotor's okay to run as-is for a little while. This car's a driver. It won't get tracked, or driven all that aggressively until I can go all the way through the brake system, so I'm comfortable now with re-pinning the pads and letting it roll for the time being.
Thanks much.
Be well,
SJW
Thanks for the advice.
Be well,
SJW
Thanks for your advice.
Be well,
SJW
