Digital distributor
Old May 30, 2006 | 10:55 PM
miechesa's Avatar
miechesa
Default Digital distributor
Has anyone tried one like MSD Digital E-Curve Pro Billet Distributor?.Less hassle,no springs/bushing. How good do they work?
Old May 30, 2006 | 11:17 PM
davidm_comp's Avatar
davidm_comp
Old May 31, 2006 | 01:38 AM
blueray72's Avatar
blueray72
Hey Paul, let me know where you got that money tree. I need one for my backyard. Seriously, that car is gonna be wickid when you are done.
Old May 31, 2006 | 01:47 AM
comp's Avatar
comp
Old May 31, 2006 | 08:26 AM
sly vette's Avatar
sly vette
I'm looking for a answer on this on myself.
Later,
Sly
Old Jun 5, 2006 | 04:56 PM
davidm_comp
Ttt
Old Jun 5, 2006 | 05:41 PM
gkull's Avatar
gkull
MSD Digital E-Curve Pro Billet Distributor is what I've had since last year. Like most things MSD sells they didn't put alot of real world thought into it. It's about money.
IMO - So what if you have 100 timing curve choices. I've only tried 4 or so. Any motor can only use a few of the choices. My heads make the most power at 32-34 degrees of advance.
So the MSD gives you the choices of 10-15-20-25-30 degrees of advance
Do the math. if I choose 15 degrees additional advance. My initial has to be 17-19 degrees. If I change the dial to the 20 degrees advance my initial is 12-14 degrees. Then the other dial is what RPM is all the advance in. The choices are something like locked out and 2500-2750-3000-3250. So left it 3000.
I have to pay sales tax down at Summit Racing. So the dist. is about $400, Crane digital Multi spark and coil $300, Taylor pro wires $130. It's about $800 to fire the plugs.
Crane Cams also has one out now. I'd like to see the possible settings to campare them
comp's Avatar
comp
really nobody
Old Jun 5, 2006 | 05:49 PM
gkull's Avatar
gkull
Yes read the above post.
Old Jun 5, 2006 | 05:52 PM
Gordonm's Avatar
Gordonm
Interesting. I thought it was infinitly adjustable. Seeing it is adjustable in steps is not a huge benifit.
Old Jun 5, 2006 | 06:03 PM
gkull's Avatar
gkull
That what I mean... the steps are to big. I'll find the directions and post what the choices actually are.
Old Jun 6, 2006 | 03:03 AM
MIKER's Avatar
MIKER
I'm using a Crane "Street Race" distributor, Crane Hi-6 ignition, and Crane LX92 Coil. It has less centrifugal and vacuum advance options than the MSD E-Curve but it's more than good enough for my needs. Beats the heck out of my old GM HEI distributor with sticky advance weights.
However, I have a worn cam gear and I suspect it is causing somewhat inconsistent timing no matter how tricky dicky my new distributor is.
http://www.cranecams.com/?show=brows...01&showAll=yes
I'm sure that a properly set-up conventional distributor can perform just as well as these new-tech gadgets. These new digital distributors are quick to set up and should remain consistent over the long haul. Almost a set it and forget it sort of deal.
I'd really like to see a dyno comparison between the digital Crane, MSD and conventional/mechanical advance style distributors to see the difference in various selections of advance curve settings.
Here's the installation/set-up manual for the Crane distributor:
http://www.cranecams.com/pdf/90001500.pdf
Here's the installation/set-up manual for the MSD E-Curve distributor:
http://www.msdignition.com/pdf/frm26...94_e_curve.pdf
Old Jun 6, 2006 | 03:21 AM
comp's Avatar
comp
dammmm it's not what i thought IT should be
To Digital distributor
