Fuel pump??
Old May 31, 2006 | 10:56 AM
69camfrk's Avatar
69camfrk
From: GA "When I grow up, I'm gonna get a Trans Am and run from the cops". Direct quote from my 4yo son.
Default Fuel pump??
I need some advice on a fuel pump. Swapping my engine and will put on a new fuel pump. The ones through Summit have no provision for the return line ('80 model). I've heard of vapor lock problems when not using this line. I need at least 6psi fuel pressure according to info that came with the motor GMPP350/330 horse. Thanks
Old May 31, 2006 | 11:02 AM
lars's Avatar
lars
If you're running a BG or a Holley carb on that engine, you can run a fuel return line off the end of the fuel inlet log, and run the line down to your frame rail to pick up the stock return line. This type of system works very well and allows you to use any pump without a return provision.
Lars
Old May 31, 2006 | 11:19 AM
S489's Avatar
S489
well, since that one was answered, how about for the case where a Mk V is installed (no provision for mech pump) on a 74 with a Q-jet? the original mech pump had a supply and vent(?) line. will it work to install a factory AC type elec pump and plug the vent(?) line? thanks
Old May 31, 2006 | 11:26 AM
69camfrk's Avatar
69camfrk
Lars
Is there any way I can do this with a single inlet feed? I'm using a Holley 4160 600cfm vac. secondaries. Thanks
Old May 31, 2006 | 01:00 PM
lars's Avatar
lars
Sure. Just install a "T" fitting in the line close to the carb inlet. Use the one branch of the "T" for the return fuel. I like to weld the hole in the "T" closed and then drill it out to about a .030" hole to restrict the return fuel flow a bit when using a near-stock mechanical pump. This will keep the pressure up at the carb while allowing a steady return fuel flow to eliminate vapor lock and hard starting.
Old May 31, 2006 | 01:03 PM
lars's Avatar
lars
Electric fuel pumps don't like to be dead-headed: It increases amp draw and increases operating temperature of the pump (with a corresponding decrease in pump life). If you can install a return fuel system your electric pump will be much happier...
Old May 31, 2006 | 01:06 PM
69camfrk's Avatar
69camfrk
Right on! Thanks for the help.
Old May 31, 2006 | 02:18 PM
S489's Avatar
S489
I agree this is not ideal, but I've got the spendometer whirling on other stuff right now! I'm not sure if i'll end up with FI or not yet - need to drive a little first. Will also install the 4L80E a little later too. I'm thinking this setup ought to get at least 6 mpg the way it is! Was trying to avoid welding on the tank until i'd decided whether to FI or not. . .whatever it ends up with in the induction, i'd decided that to pump with a back pressure regulator after the carb/FI appeared to be the way to go. But need to just get by right now. . .
Old May 31, 2006 | 03:58 PM
VetteNut72's Avatar
VetteNut72
Lars is indeed correct about a return line with an electric pump.
Here is where I mounted my pump (body on now, everything clears good)
The line running on top of the frame is the return line. The 'T' fitting supplies return fuel to the pump for priming purposes. That compression fitting that transitions the braided line to the hard line leaked at pressure test so I now have it sleeved and flared.
This shows how I routed the supply and return lines
They terminate at frame mounted bulkhead connectors
and connect to engine mounted bulkheads via braided line.
Craig
Old May 31, 2006 | 04:20 PM
S489's Avatar
S489
Craig,
what mods were required on your tank?
does return go to tank of suction side of pump?
looks good!
Old May 31, 2006 | 04:52 PM
VetteNut72's Avatar
VetteNut72
Craig,
looks good!
Thanks, four years now and counting . Owned her for 11 years and I've almost forgotten how it feels to drive it
I drilled the tank and mounted a 6AN male for the return line to connect to:
And welded an 8AN male on the tank pickup:
I know from others experience here with high pressure fuel systems that I will have a problem with fuel pickup when the tank is less than 1/4 full. I plan on setting up another tank, with a sump, and installing it in the future.
Craig
Old May 31, 2006 | 05:33 PM
enkeivette's Avatar
enkeivette
Vapor lock? Que? I've been running a mechanical fuel pump with no return line for almost a year now, no problems. I'm using a Carter Strip pump, it makes about 7psi, sometimes a little more. The Carter street pump only made about 5psi, despite what the description claims. If I were you I'd just buy the strip pump with a holley fuel pressure regulator and set it at 6spi, the regulator will have a return port built in and you can send that to your return line. You should be able to buy both for about $100.
To Fuel pump??
