Re: Rotors Riveted...how do I replace them? (TJKirby82CE)
On my 75 I just ground the heads off the rivets and knocked them out with a punch. :smash: When I purchased my new rotors I also purchased a rivet set with them. I have been told you can get rotors that you don't need to rivet on but I'm not sure if thats a true statement or not.
Slide
Ok I know how to get them off now. But how do I put them back on....do I need some type of rivet machine, or what, please be detailed this is my first front end rebuild.-TK
Thanks guys! :smash:
I put the rivet through the hub and the rotor then set one end of the rivet on a piece of steel round stalk and hammered the other end flat. If you have access to riveter or a press it would be a heck of a lot less work, believe me!The way I did it takes a lot of :smash:
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
You don't need to re-rivet the rotors to the hub, unless you're after that NCRS look. The hub & rotor were originally rivetted to ease assembly at the plant.
The rivets do not need to be replaced. Also, if your current rotors are not to bad they can be turned on the car. I had this done at our local Western Auto for about $75.00.
