Firewall Clearance for HEI Conversion
Old Jun 2, 2006 | 06:36 AM
71-Stingray's Avatar
71-Stingray
Default Firewall Clearance for HEI Conversion
I am replacing the stock distributor in a 1971 350 with an HEI unit. I don't think I should have any clearance issues, but I am unable to check at the moment because the body is off the frame. (In comparing the 2 distributors, the HEI unit is significantly larger in diameter)
Old Jun 2, 2006 | 07:15 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
No fitment problems with the HEI. I have had one in my 69 before.
Old Jun 2, 2006 | 07:28 AM
71-Stingray
Thanks - that's what I wanted to hear!
Old Jun 2, 2006 | 08:37 AM
stingrai's Avatar
stingrai
Some cars I have done have hit the washer cover on the wiper motor, on those cars, I upgraded to the newer style motor, with no washer pump gearing and a flat cover, and used an electric washer pump. It appears on some cars, a little less clearance to the washer assy than others. Make sure you check yours, especially taking into consideration, some engine flex/movement while driving.
Old Jun 2, 2006 | 09:41 AM
71-Stingray
Thanks for the input. I'll hold off on installing the washer pump until after the body is droped back onto the chassis.
Is that the standard configuration for a '75 and later - i.e. a remote electric pump versus a motor mounted pump?
Old Jun 2, 2006 | 09:52 AM
litevette's Avatar
litevette
I also have a 69' wich i converted to HEI. The only concern you may have is the tach. Unless you are going with an aftermarket tach too. The standard distributor doesn't have the (cable?) same drive system to run the stock tach.
Old Jun 2, 2006 | 09:55 AM
stingrai's Avatar
stingrai
You can install a 1975- 1976 Tach, which is elect, and would fit in your dash, lots of these available used if you look, this will leave it stock in appearance, and yes , newer cars that came with HEI would have the flat wiper motor, and electric washer.
Old Jun 2, 2006 | 10:19 AM
71-Stingray
Thanks for the feedback.
Fortunately, the tach won't be a problem because I purchased a HEI unit that has the tach drive gear on it. The only new wrinkle is the wiper motor and washer pump - and it sounds like the workaround is to use a setup similar to a '75.
Old Jun 2, 2006 | 11:14 AM
crazywelder's Avatar
crazywelder
Obviously your ignition shielding won't fit, but '75 (HEI) still had a chrome distributor cover and side shields.
Old Jun 2, 2006 | 11:45 AM
71-Stingray
Good Point
My ignition shielding was removed long ago by some previous owner; as such, I never gave it much thought. However, I do like the idea of adding the '75 chrome pieces.
Old Jun 2, 2006 | 03:07 PM
halfmoontrail's Avatar
halfmoontrail
I put a stock GM HEI on my tripower big block with no fit problems, it is tight behind the rear carb, though.
Also, I put the distributor in where it fit best, set up wires and timing from there.
Old Jun 3, 2006 | 04:57 AM
aussiejohn's Avatar
aussiejohn
Default Caution
Marathon,
I too, have a tach drive HEI distributor in my '74 and the thing to watch for is the clearance between the "square" boss on the dist. where the wires go and the air cleaner. This boss sticks out at about 10 o'clock if you're behind the engine and you have to have it here to get the tach cable to come out at about 9 o'clock so it has a smooth bend into the dash. You need the vacuum advance canister at about 3 o'clock so dummy it up on your engine this way while it's out of the car and see if you have clearance.
Regards from Down Under
aussiejohn
Old Jun 3, 2006 | 07:42 AM
71-Stingray
Thanks for the heads up! I'll get it set up as you describe then drop the body down.
Old Jun 3, 2006 | 09:09 AM
TopGunn's Avatar
TopGunn
This is a pic of a 75 HEI with the cap off I took for someone but you can see the clearance and the wiper motor.
Bill
To Firewall Clearance for HEI Conversion
