Flowmaster 40 Series muffler..????
Old Jun 3, 2006 | 04:02 PM
LannyL81's Avatar
LannyL81
Default Flowmaster 40 Series muffler..????
Have Flowmaster mufflers, part number 42441 which is the 40 Series with 2.25" in/out. They were on the car when I got it.
Everytime I take the rear exhaust section off for some reason, I dump rust parts out of them. I finally got feed-up and took them off today and gots lots of rust parts out of them. They were quiet...nothing like the Magnaflows I have on my 96 LT4.....Is this normal for the 40 Series or or mine just plugged-up with rust?
Got to get new mufflers.
And no I cannot get side pipes due to emissions....same for headers...at least not until Arizona passes the 25 year old car - no emissions required law....keeping my fingers crossed.
But until then.....guess I will go with the Magnaflows from Corvette Central...is this the best price for bolt ons?
Thanks in advance,
LannyL81
Old Jun 3, 2006 | 06:32 PM
supervette2's Avatar
supervette2
well 2.25 isn't a very big diameter and if there not mandrel bent the restriction will be down to 2 inches. As far as the rust issue goes that doesn't sound good at all. Id replace the whole exhaust with 2.5 inch mandrel bent exhaust with an H-pipe and flowmaster 40s it should be loud then
Old Jun 3, 2006 | 08:17 PM
oregonsharkman's Avatar
oregonsharkman
I've got 2.5" flowmaster 40's....Definitely no rust thang.......that just doesn't sound right.......2.25" is pretty restrictive for a decent 350............And 40 series are anything but quiet, you must have them really plugged up.
Old Jun 3, 2006 | 08:33 PM
supercalvin's Avatar
supercalvin
I have those Flowmaster 40's as well. They have a great rumble to them.
They came with my car and are around 4 or 5 years old.
Old Jun 3, 2006 | 10:35 PM
Restorod '79's Avatar
Restorod '79
Rust in AZ? Are the exhaust tips pointing up? Taking on rainwater?
I also run Super 40s on dual 2.25- mild 350- very loud, deep, throaty.
Old Jun 5, 2006 | 10:31 AM
LannyL81's Avatar
LannyL81
No the tips were not turned up catching rain water.....besides...it never seems to rain here in Tucson anymore...
All I can say is that a little bit of shaking and I get a rattle. Dump out more rusted guts. Just when I think I have it all out....out comes another piece.
But I would think that the muffler would get louder with all the baffles falling out....tempted to put them back on and see if they flow any better. I tried pushing a wire into both inlet and outlet...only went a short ways in. Do not know what what these Flowmasters look like on the inside as far as chambers and such.
Probably just order a new set of Magnaflows from CC and be done with it.
LannyL81
Old Jun 5, 2006 | 10:48 AM
69autoXr's Avatar
69autoXr
I had a Flowmaster 40 series rust through from the inside after about five or six years. My car doesn't see enough rain for that to cause it, I assume it was caused by condensation in muffler after the engine was shut off.
Old Jun 5, 2006 | 11:17 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I just took a Flowmaster 80 series muffler off my DD. The muffler looks still fine after 4 years and roughly 60000 miles. I had about 2lbs of rust chunks on the floor when I took it off
Old Jun 5, 2006 | 11:51 AM
MsVetteMan's Avatar
MsVetteMan
Hmmmm...not to alarm you, but something doesn't sound right. Rusting of very old mufflers is quite common, but new mufflers would have to be exposed to a fair amount of moisture/condensation to rust out like that. How's your engine running? You sure you are not blowing water out the exhaust in a fine spray? Cracked block or heads could be your problem, or a problem you can't identify as of yet.......
Old Jun 5, 2006 | 12:01 PM
rihwoods's Avatar
rihwoods
They were on the vette when he got it..no telling how old they are...
LannyL81:
Get new mufflers...you won't get all that rust out of those things..and your cat is probably gone too...get a 3" high flow cat...
Old Jun 5, 2006 | 01:48 PM
Bee Jay's Avatar
Bee Jay
I thought flowmasters were stainless, or alumanized, or something that isn't suposed to rust?
To Flowmaster 40 Series muffler..????
