Engine vibration....
Old Jun 3, 2006 | 07:42 PM
toyvet1's Avatar
toyvet1
Default Engine vibration....
I have a 79 with a slight vibration above 2500 rpm. The engine is 383 with TPI that was balanced when built. I have replaced the flywheel and clutch with no luck. At highway speed car vibrates until you slip the clutch and the car becomes rock steady. I have put new dampner,pulleys, distrbutor, and all new ignition parts. I removed the belts with no luck. Any ideas where to look next....
Old Jun 3, 2006 | 07:44 PM
SIXFOOTER's Avatar
SIXFOOTER
U-joints
Old Jun 3, 2006 | 08:03 PM
toyvet1's Avatar
toyvet1
forgot to mention it happens while car is at as standstill..
Old Jun 3, 2006 | 08:29 PM
...Roger...'s Avatar
...Roger...
So your saying that you have this vibration at 2500 in neutral? You said on the road it would straighten out when you slip the clutch.When you press in on the clutch you are forcing the crank forward--too much crank endplay?Did you say you stiill have the vibration at 2500 and all the belts removed?Did you have the flywheel and clutch balanced together?
Old Jun 3, 2006 | 08:31 PM
...Roger...
Has this engine vibrated since you put it in?Maybe the balance job was bad.
Old Jun 3, 2006 | 08:40 PM
...Roger...
I had a 78 L-82 with18000 miles that I worked step by step until I narrowed it down to the crank.Stock original crank-surprise--Mon. or Fri. crank?Who knows!
Old Jun 3, 2006 | 09:18 PM
croaker's Avatar
croaker
Mine does the same thing when you stick the clutch smooths out it's most noticable in the rear view mirror mines a L-82 rebuild I'm suspecting something in the drive train ,but I'm putting on a new G.M. damper next week keep me posted on any progress I'll do the same
Old Jun 20, 2006 | 09:52 PM
71-Triple Blk's Avatar
71-Triple Blk
Did you replaice the pilot bearings?
Old Jun 20, 2006 | 11:46 PM
toyvet1's Avatar
toyvet1
I just rerplaced the whole flywheel,clutch disc, pressure plate and roller pilot bushing and the vibration is gone. Dont know what was wrong with the old clutch(300 milws) but it runs smooth now..
Old Jun 21, 2006 | 02:12 AM
Bangkok Dean's Avatar
Bangkok Dean
Glad to hear you have sorted out your problem
To Engine vibration....
