Harmonic balancer woes
Old Jun 17, 2006 | 07:09 PM
SmokinBBC's Avatar
SmokinBBC
Default Harmonic balancer woes
It has been one of those "while I'm at it days"...
Yesterday, went to drain the radiator to do a flush....drain plug came out of the radiator...no biggie, nothing damaged...put it back in with JB weld.
Well, while I was at it, I might as well install the cloys timing chain set. ( Was going to wait until the fall, but what the heck). Didn't take long to take everything out to get to the harmonic balancer....
That sumbiatch won't budge! Stripped one puller...picked up another one...got it pretty tight, tapped the puller bolt with a hammer..tightened again..tapped again, tightened again tapped again...still doesn't look like it budged....150lb psi impact wrench did not budge it!
Oh well, takin a break! get back to it later....
Old Jun 17, 2006 | 08:04 PM
Meh's Avatar
Meh
Just grab it with your teeth and twist it off...
Old Jun 17, 2006 | 08:45 PM
SmokinBBC's Avatar
SmokinBBC
Now that's funny!
Old Jun 20, 2006 | 07:09 PM
SmokinBBC's Avatar
SmokinBBC
Victory!
Old Jun 20, 2006 | 07:12 PM
C3 Stroker's Avatar
C3 Stroker
Originally Posted by SmokinBBC
Victory!
.....wait till you try to put it back on..
Old Jun 20, 2006 | 07:19 PM
68 NJConv 454's Avatar
68 NJConv 454
hope you didn't chip a tooth
Get a new one or clean that one up real well.
Old Jun 20, 2006 | 07:46 PM
SmokinBBC's Avatar
SmokinBBC
Still have all my teeth
It is in very good shape...it will clean up just fine!
I have an installer tool....that will be fun...not!
Old Jun 21, 2006 | 03:09 AM
langlj00's Avatar
langlj00
Default SBC Balancer
Hummmmmmmmmm.
Just done mine (last weekend). Getting it off was a breeze
Putting a new one back on
Now that was hard.
Frozen peas on the crank snout
The balancer in the oven at 120 Deg. C
Oh yes and I'm bruised to hell - that'll teach me to do it in the car without taking the rad. or shroud out.
Anyway - its done - GOOD LUCK
Jeremy.
To Harmonic balancer woes
