Engine cuts-out
Old Jun 4, 2006 | 09:16 AM
AirTrafficController's Avatar
Default Engine cuts-out
Things were going fine. I drove for about 30 minutes, no probs. Then on the way home, around 60-65mph @ 2500 rpm, the engine just cut out, all of a sudden. No backfire or anyother indicators, just a complete loss of power until I slowed down. I made it home, but I noticed it would cut out at lower speeds, too.
It can only be 1 of 2 things - electrical or fuel. I'm going to start first by looking at the total advance. Any suggestions appreciated
Would a bad coil cause this? It's weird that it took 30 minutes of driving for this to show up. I was thinking it was the engine heat maybe?
Old Jun 4, 2006 | 09:40 AM
marshrat99's Avatar
marshrat99
I agree that it is most probably fuel or ignition. If you've not changed the fuel filter in a while, I'd start there. Next I'd have a look at the plug wires, points, distributor cap. I had a similar problem this spring and turned out to be a burnt plug wire on #5. These little problems are hard to diagnois but easy to fix once found.
Old Jun 4, 2006 | 10:00 AM
...Roger...'s Avatar
...Roger...
Default For fuel to come out air must go in!
If you decide it is starving for fuel start at the tank.Loosen the gas cap and see if this helps,if it does help check charcoal canister or check valve on side of tank.
Old Jun 4, 2006 | 10:48 AM
Default Problem solved !
It was a collapsed fuel hose -from the steel body line to the fuel pump. It's a new piece of rubber, but apparently, after heating up, it collapsed and pinched off the fuel flow. Do they make a molded piece, or should I just use a longer piece next time?
footnote: I don't have the cannister on mine (non-ec). I do notice when I remove the gas cap, I get the pressure of the vapors escaping. I figure this is normal.
Old Jun 4, 2006 | 10:53 AM
...Roger...
Pressure is OK but if its vacumn that could have collapsed the hose and yes they do make a molded one.Where does the air come into your tank.
Old Jun 4, 2006 | 10:59 AM
...Roger...
Do you have a vented cap---GM book shows a 70 is non vented.
Old Jun 4, 2006 | 11:03 AM
...Roger...
Molded fuel hose Ecklers #A8360 frame to pump(flow to pump)#8361 vapor return
Old Jun 4, 2006 | 12:56 PM
Cap is non-vented. It has a return line running parallel with the feed line. I installed a new OAL-stamped gas tank about 6 mo. ago. It's got the check valve (?) on the top of the tank, and I believe that's what keeps the tank from collapsing by allowing air to come in at a certain point.
I've ordered the molded fuel line and hope that's the end of that
To Engine cuts-out
