more welding and cutting
Old Jun 5, 2006 | 12:16 PM
Kid Vette's Avatar
Kid Vette
Originally Posted by Socket Head Bolt
I see you triangulated it differently. Still looks good lol.
Hey, I see your still around. Are you planning to go back to your previous user name once "Banned Camp" is over?
Old Jun 5, 2006 | 12:18 PM
Twin_Turbo's Avatar
Twin_Turbo
Who is he? Obviously not yellow73sb ?? Is it tony? (I thought nacho libre was tony)
Old Jun 5, 2006 | 12:32 PM
Kid Vette's Avatar
Kid Vette
Obviously is.
Old Jun 5, 2006 | 12:58 PM
Twin_Turbo's Avatar
Twin_Turbo
humm..just looked through some of his posts... a little childish indeed w/ all the LOLing going on...maybe it is the kid.
Old Jun 9, 2006 | 12:02 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
couldn't find the other thead where we talked about the layered grinding disks....i saw some at lowes yesterday about $13 a pop and they come in 60, 80 and 120 grit.....what are you and Norval using??? how long do they last and as the top layer gets worn away does it "peel away" to another layer? thanks bob
Old Jun 9, 2006 | 12:19 PM
Twin_Turbo's Avatar
Twin_Turbo
I'm using 80 frits usually. 13$ a pop? Holy sh!!! I get them for 2.50 or so. They last reasonably well but I use them quite a bit. I buy them in packs of 10. As the top wears away so do the layers, you can wear them down all the way to the adhesive. Sounds like a good way to make money, send those discs over the pond and charge 5$ a pop, that's 25$ on a box LOL
Old Jun 9, 2006 | 12:42 PM
xcelciador's Avatar
xcelciador
I haven't seem much progress of your car. Do you have any more pics of your car and it's fabricated parts?
Old Jun 9, 2006 | 02:30 PM
bobs77vet's Avatar
bobs77vet
thanks, sounds like i need to keep looking for a cheaper supplier
Old Jun 9, 2006 | 03:49 PM
norvalwilhelm's Avatar
norvalwilhelm
I am using the same ones as Marck and they run about $12 after tax hear. Lucky for me my son buys them in quantities of 125 at a time and sometimes goes through them in a few days. He always makes sure I have a good supply.
That and the thin cutting discs and the grinding wheels for welds are the 3 consumables I use the most.
I use the sanding wheels right down to just about the plastic. New nothing seems to cut as fast as them. I use the grinding wheels for welds first and then switch to the abrassive wheels for finishing up.
4 1/2 inch grinders are only $29.95 here so I bought 6 of them so I don't have to change wheels all the time.
Old Jun 9, 2006 | 10:24 PM
bobs77vet's Avatar
bobs77vet
Originally Posted by norvalwilhelm
.........4 1/2 inch grinders are only $29.95 here so I bought 6 of them so I don't have to change wheels all the time.
they are cheap here also but I only have 4 of them.....so next time to harbor freight i will have to look for layered disks and a dedicated grinder for them!!!
Old Jun 9, 2006 | 10:27 PM
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
can you imagine if you and Lars got together to make a car??? that thing would be amazing!
Old Jun 9, 2006 | 10:45 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Marck,
have you done any destructive tests on your welds?
Old Jun 10, 2006 | 06:55 AM
  #33
Twin_Turbo's Avatar
Twin_Turbo
Yes, I know my welds are sound. I chamfered all the pieces for full root penetration
Old Jun 10, 2006 | 07:22 PM
  #34
shafrs3's Avatar
shafrs3
Well..I worked some more on my custom dual a arm rear suspension and have the upright figured out for the most part. I only welded in 1 side on this upright but the parts are ready to fully weld both sides, only thing left is to properly position the upper arm bolt hole (has to be inline w/ lower arm hole and u joint)
I decided to use 3/4 heim ends instead of 5/8th. I pressed a reducer sleeve into the rod end to reduce the hole size to 5/8th...cheaper than buying a new set of these aurora rod ends.
I also drilled holes in the round middle section, I will also drill some holes in the 2 legs where there's room. As of now the assembly is pretty light, a lot lighter than the stock trailing arm.
I'll start work on the lower arm pretty soon.
Beautiful welds...
Old Jun 10, 2006 | 09:25 PM
  #35
Bismarck's Avatar
Bismarck
I like to achieve full root penetration myself.
Old Jun 10, 2006 | 09:27 PM
  #36
Bismarck's Avatar
Bismarck
Sh*t, I have been achieving full root penetration for years and I never claimed to be a fabricator, although it did spring up a few offspring.
Old Jun 10, 2006 | 11:00 PM
  #37
bobs77vet's Avatar
bobs77vet
well i'm almost embarrased to say that today when going to change a grinding wheel I found a bunch of layered disks today that i bought some time ago...its either the beers or the age ...i can't remember crap anymore
To more welding and cutting
Old Jun 11, 2006 | 01:21 AM
  #38
redc3's Avatar
redc3
impressive.not only are you a vette guy that works on his own ride ( an oxymoron ), your are very tallented
Old Jun 11, 2006 | 03:06 PM
  #39
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
You don't hang around here much, do you? Most of us do our own work.
Old Jun 11, 2006 | 04:07 PM
  #40
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Awesome
