C3 Carpet Question
Old Jun 5, 2006 | 09:17 AM
IDOXLR8's Avatar
IDOXLR8
Default C3 Carpet Question
I have a 68 coupe, and I installed the black rubber backed jute and the carpeting I got had jute on it. I found out the carpet is sold with and without the jute on it. It seems to have to much padding. Should I have got the carpeting with out the jute? AL.
Old Jun 5, 2006 | 09:38 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Unfold the carpet & lay it in the car. You may find that the fit is OK. That's the only way to really tell.
Old Jun 5, 2006 | 09:46 AM
CGGorman's Avatar
CGGorman
You can just pull the jute off the carpet if you think it's too thick. Sounds like you've got about 3/4" between the two layers of jute, right? That's pretty thick, but it might work. Just be careful around the pedals. I had to keep mine very thin there to maintain full pedal travel.
Old Jun 5, 2006 | 09:50 AM
IDOXLR8's Avatar
IDOXLR8
Correct me if I'm wrong, what I remember of what I removed was the carpet (no padding) sitting on a black rubber backed padding glued the the rear compartment, AL.
Old Jun 5, 2006 | 10:46 AM
CGGorman's Avatar
CGGorman
My rear compartment was bare carpet against glass...except the fender areas. Those had jute glued to the carpet. I replaced everything with the Al Knoch kit and their's was the same construction as what I pulled out...
Old Jun 5, 2006 | 11:14 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by IDOXLR8
....carpet (no padding) sitting on a black rubber backed padding glued the the rear compartment, AL.
Sounds like a previous owner had installed heat shielding in the rear compartment. You might also find it under the jute in the front.
Old Jun 5, 2006 | 12:26 PM
Edzred72's Avatar
Edzred72
Yep!!!. With double padding you'll have to remove the jute under the seat tracks or buy longer seat mount bolts. Difficulty with shift console mounting, shoulder belt retractor mounting and seat belt buckles on the tunnel too. Go single thickness on the jute...
Eddie
To C3 Carpet Question
