this is so frustrating the more things i fix the more that quit working gag
oh well on to the new problem no brake lights fuse in panel good, brake light swich good at least i think so when I cross the contacts of the female end going into the switch i still get nothing what am I missing
Thanks hazards work turn signals work--78 SA
You have power from the turn signal, but not from the brake light? If you have th eright bulbs and they're good then check to see if you have power to the socket when someone else presses the pedal. Use a meter or 12 volt test light to ground to see if you power to the socket. Could be you have no power or a bad connection. SOunds like you have a ground because the signal light works. Check the bulbs and wiring.
Gary
If you bypass the brake switch the lights should come on. If so then check for power at the switch and then step on the pedal and check for power after the switch. If no power after and you have power before then the switch is bad. If not then it seems that you probably have a problem with the wiring going to the column from the brake switch. It could be in the column going to the turn signal switch as the brake light circuit runs thru it. However if the hazards work right and the turn sigs work fine then the switch and all wiring after it should be good. Hope this helps saome.
