New crates auto shift points to quick?
Old Jun 6, 2006 | 10:47 AM
MsVetteMan's Avatar
MsVetteMan
Default New crates auto shift points to quick?
Well, the new crate is broken in!! After slammin' the accel. down a few time all the way, I noticed that the auto. is shifting really quick. Not getting the maxximmum rpms/torque out of each gear like I think it should. Can this be adjusted with the timing curve? Or is this strictly a rear end gearing/tranny situation?
Anything I can do to extend the time between shifts without messing with the tranny or rear end? I guess I could manually shift through the gears of the auto when so required! What do you automatic guys do?
I knew this was going to take me to a new part of the car I know nothing about...........
Old Jun 6, 2006 | 11:22 AM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Shift manually when you want max rpm from each gear. At least that is what I do. My experience is that if you simply leave it in drive, (TH 400 at least) the shift will occur at approx 80% of peak.
Old Jun 6, 2006 | 11:46 AM
gyopp's Avatar
gyopp
Did you hook your throttle kick-down cable back up? It may need to be adjusted. Check and see if it will shift to passing gear when you call on it at highway speeds.
Gene
Old Jun 6, 2006 | 11:53 AM
marshrat99's Avatar
marshrat99
When I had my Th350 in my 79, under mild acceleration the shifts came quick also thanks to the 355 rear. However, launching from stop using a hi-RPM stall and then WOT, the shift point was at 5,500RPM.
Old Jun 6, 2006 | 12:37 PM
MsVetteMan's Avatar
MsVetteMan
Gene
Yep, it's hooked up and working. I seem to be shifting about 4500 rpm......is this about right for an auto with stock tranny and rear end?
It seems to do pretty well through first gear (though will still shift quicker than I like on open throttle) , but 2 to 3rd is the one that occurs pretty quick.
On typical driving, it seems fine.
If you are going to manually shift the 3 spd. auto, what rpm's should you shift at for each gear for full throttle?
Old Jun 6, 2006 | 12:47 PM
Brettmc's Avatar
Brettmc
Doesn't the vacuum modulator control shift points on the TH350??
Brett
Old Jun 6, 2006 | 01:04 PM
MsVetteMan's Avatar
MsVetteMan
Brett
I'm not sure it controls the shift points, but it does control the actual shifting. I accidently left mine unhooked at the vac connection on the intake and couldn't get out of first gear one day!!
Anyone clear this up?
Old Jun 6, 2006 | 01:37 PM
CheezMoe's Avatar
CheezMoe
The upshifts are controlled by the vacuum modulator. Therefore, the shift point will change with engine specs.
I have never seen a stock AT that will get you to the top of the curve while in drive.
Shift manually at the rpm stated on the build sheet where you have just exceeded max HP. You may need to experiment and get to know your best shift point by the seat of your pants, literally.
You could also have the tranny tricked out.
Old Jun 6, 2006 | 02:12 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I had to replace my modulator valve and wasn't able to get a direct replacement. The two that I tried shifted too low, just as you described. I was able to solve the problem by getting an adjustable modulator (Kragen, Pep Boys...) and adjusting it all the way. You could also get an upgrade kit from TCI or B&M. Some of these have modulators as well.
Old Jun 6, 2006 | 05:31 PM
MsVetteMan's Avatar
MsVetteMan
Thanks, good info.!! For now I'll think I will keep it as is.......
Old Jun 6, 2006 | 08:34 PM
MsVetteMan's Avatar
MsVetteMan
sum biatch.......!! Got got in from a late afternoon cruise/hammer session......Running through the gears manually shifting the auto make all the difference in the world!! I felt every bit of torque this biatch has this evening, and then some!! Oh my........
Do have a question...Is there some type of built in protection in the 350Th that will keep it from shifting in high rpm's? I noticed that when I was close to or at redline, it would not shift, but when I eased off the throttle a bit, it would fall right in........
Old Jun 7, 2006 | 12:31 PM
Brettmc's Avatar
Brettmc
Did you put a shift kit in it? Are you catching 2nd? 3rd?
I put a strong 400 in that 69 Camaro I used to have. The TH350 in it gave up trying to handle the torque one nite. I had it rebuilt and had the rebuilder put a kit in it. It would catch third most of the time.
Old Jun 7, 2006 | 12:47 PM
MsVetteMan's Avatar
MsVetteMan
Nope, no shift kit. Just manually shifting through the gears. Tranny may be slipping.......rut row......
Old Jun 7, 2006 | 12:54 PM
S489's Avatar
S489
not too sure about TH350, but the TH400 has a govenor that controls the shift points. it can be adjusted by changing springs or weights. i've had both trannys, shifted both manually, and had rather get them to shift automatically at the right time. i always notice too much delay when shifting manually. this may be what you noticed near redline-if you just kept the loud pedal down, it should eventually shift. . .
take it to a reputable shop and have them adjust. shouldn't cost that much.
Old Jun 7, 2006 | 01:47 PM
MsVetteMan's Avatar
MsVetteMan
Yep, definetely as you describe, it's more like a delay........I found that if I eased off at redline, it would go ahead and shift, but that's defeating the purpose.
Old Jun 7, 2006 | 02:01 PM
Brettmc's Avatar
Brettmc
You've got to click the shifter before you want the tranny shift. I had the delay down pat on the Camaro. Don't have to worry about that with the 74's tranny tho....
Old Jun 7, 2006 | 09:07 PM
wogs73's Avatar
wogs73
You can get a governor spring and weight kit from B&M through Jegs or Summit. You can then play with the springs first and get the shift point where you want it. I did this with my 350 trans and got it close to where I want it. Not a hard thing to do, just follow the directions.
To New crates auto shift points to quick?
Old Jun 7, 2006 | 11:01 PM
MsVetteMan's Avatar
MsVetteMan
Thanks for the responses!! Spring thing is interesting........hmmm.........link?
Old Jun 8, 2006 | 12:28 AM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Just used the B&M spring and weight kit on my 400. With the middle weights and springs it produced a 4800 rpm shift (1-2) was 4200 stock. I just installed the lightest springs and weights. I hope to test soon. My car is not a street car, otherwise testing would already be done. If you decide to modify your governor keep the nose of your car lower (4-6 inches) this will keep you from losing very much fluid. I will post my results as soon as I get to the track, but it'll be a couple of weeks. Ron B.
Old Jun 8, 2006 | 06:48 AM
jdmick's Avatar
jdmick
This guy's site has some good info on governors and other 700r4 tuning items.
http://iotech.no/corvette/technical/700r4/index.htm
