How to remove the alternator fan and pulley (76 L48)?
Re: How to remove the alternator fan and pulley (76 L48)? (JRChurch)
it comes off counterclockwise and i use an impact gun to take it off if you can hold the fan tight and a wrench maybe you can get it to brake it loose.
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
I just wrap a belt around the pulley to hold it with while backing off the nut.
Dave
Dave
Re: How to remove the alternator fan and pulley (Rolling Thunder)
If you think about the direction the engine is turning, the fan bolt will be the opposite direction.
