You can get a wide band sensor at NAPA. Try to find the voltage for each A/F ratio step for this sensor. If you can get the voltages you can use a volt meter to read the sensor.
BigBlockk
Later.....
Sorry, won't work on a WB sensor. They are totally different animals. The WB sensor is a pump cell and needs a driver box. The NB generates a voltage which you can measure, the WB does not. The WB has to be fed a varying current and the mixture is indicated by how this current varies.
reading the spark plugs can work but you can only see the spark plug color for the rpm and load that you did the plug check at. spark plug reading is not as easy as it once was unless you are using race gas, unleaded gas does not leave color on a plug until the air/fuel mixture is very rich. I only read/look at the plugs for heat range and signs of detonation but do what works for you! i prefer to use modern technology
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
I am thinking of getting the LM1 or one of it's upgraded models to tune my drag race car. It will make tuning a lot faster, a lot easier and a lot more accurate.
With a wideband with record features it's like watching a video camera of your run. You can see if you were rich or lean right on launch, how the a/f ratio is at every RPM range, how the shift affects the car, look for tire spin - all sorts of info if you know how to read the data.
A lot more than can be gotten from just reading plugs at the end of the run.
Where are you guys installing the O2 sensor? I am about to install hooker header sidepipes and have seen only one photo with this setup and an O2 sensor. It was located on the top (12 o'clock) of the tubing just past the collector with a wire running through the vent in the fender. Not pretty! Is this the only place to locate the O2 on that type exhaust? Is this a temporary setup that can be removed after "dialing in"? Do both sides need an O2 sensor, or bung? Are two sensors required or will one do, changing sides to verify readings?
Thanks. . .
Thanks. . .
you can use the innovate motorsports exhaust clamp (it goes into the tailpipe/exhaust outlet) for temporary use it is fine but not as good at idle and low engine speed as a sensor mounted in the header. there is a picture of a exhaust clamp & sensor in a side exhaust of a 1967 427/435 in the july 2006 issue of corvette fever on page 34
Thanks. . .
You can mount it from 9-3 o'clock, this keeps water from pooling/condensing in it on cool down, only 'need' to have it on one side but some people use 2 to determine if one bank is running richer/leaner than the other
Thanks. . .
Lots of good info. I don't have anything to add except to say that I installed an AEM wideband right after buying my car. I wanted a permanent unit that fit into a gauge pod. Works very well. I didn't even have to touch anything, as it appears that my car was previously tuned on a dyno.
Thanks for all the info; now i'll try to go get a little more educated.
Great link Vesa!!!
Thanks Fevre, i've seen one instruction say to install at least 10 deg above horizontal. either way, on the sidepipe that means no way to hide. this is not so bad to tune a carb, but would be dissappointing for an injected engine i think.
I need to jump on board with the kudos for the LM-1. I installed nitrous on my 82 w/ TBI and there is precious little info on jet sizes for this setup. I made my first passes on NO2 and found I was running way rich at a F/A of 9.1. I'm gradually increasing my nitrous jet sizes, sneaking up on 12.5 to one. Without the LM-1 or similar, I would be shooting in the dark.
Plus you can print out the results in and impress your friends. I am really hooked now and thinking of adding the accelerometer package. With this you can generate HP data, just like having an on board dyno. You know the saying “Knowledge is power”, horsepower!
Can these A/F meters be run by one person or do yu need someone to drive the car while another reads the meter?
Once I have my car running right I'd like to look into getting one of these meters to get the car set up to it's potential.
You can do it alone - of cource WOT testing is "fun" - like monitoring close any gauge when doing your best quartermile run
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It will record up to 20 minutes of A/F, RPM, Throttle postion and Manifold vacuum if you have the extra sensors. THen you can play it back on your computer or you can download a graph showing all the readings.
YOU can also look at it in real time with a digital readout on the meter itself or hook it up to a laptop and see all the measurements in realtime.
