Shock tower Brace Complete
Old Jun 10, 2006 | 02:17 PM
xcelciador's Avatar
xcelciador
Originally Posted by BerniesVette
I really didn't expect to feel much difference after installing the shock tower brace but there is a big difference! I could feel the front suspension working better now. There must be quite a bit of flex in the frame because I could feel the road where I couldn't before. I get a tighter feel in the suspension and can tell the suspension is reacting quicker now. I'm really impressed with the difference in the feel of the car now!
Bernie
When I jack up my car the shock towers probally move about 1/4 inch. That is alot of flex . Thats why the towers crack. It's like bending a paper clip back and forth.
Old Jun 10, 2006 | 02:41 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Glad it worked out so good. I was wondering how it would be felt in a coupe. I know in my convertible, it really made a big difference in the way feels. Don't you just love it when a project turns out as good as this one did. Good job.
Old Jun 10, 2006 | 03:40 PM
BerniesVette's Avatar
BerniesVette
I'm going to take it to the car gathering this evening. While I was doing this I found that only one electric fan was working; had a loose wire going to the right fan. With one fan it was still cooling at 190 degrees. I did have a problem with the stock fan. The tip of the rear part of the blades hit the bolt slightly. I think I will take it to a machine shop and have the tips ground and checked for balance. I do run the car with 2 twelve inch electric fans and the stock fan. I will drive it with just the electric ones for a while at least.
This was an easy and cheap project that delivered much better results than I had anticipated! I would suggest to everyone to do this upgrade. It really has to strengthen and stiffen the front frame and suspension parts.
Bernie
Old Jun 10, 2006 | 05:15 PM
xcelciador's Avatar
xcelciador
Bernie
If you keep the stock fan and It doesn't pull as hard as the electric fans It would make the cooling worse. Just something to consider.
