Secondaries not working right...
Old Jun 8, 2006 | 01:14 AM
Muddywaters's Avatar
Muddywaters
Default Secondaries not working right...
When I open my secondaries 72 LT-1 Holly 6239 vacume....they open, I feel a strong pull (for a split second) then starts missing. Acutally decreases in speed. Do the vacume secondarys need adjusting and can I adjust them? Thanks in advance. Muddy
Other than that...the engine and carb work perfectly...ummmmm
Old Jun 8, 2006 | 06:45 AM
Gordonm's Avatar
Gordonm
You can put in a different secondary spring. Lighter or heavier spring as needed. Holley has a kit that has a bunch of different springs in it.
Old Jun 8, 2006 | 09:49 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Just a thought, Maybe it's running out of fuel. As the secondaries open it is calling for more fuel. If you haven't already done it, I would check your secondary float bowl level. I had this identical problem once before and found the secondary float bowl was too low.
Old Jun 8, 2006 | 10:04 AM
Muddywaters
Thanks Gordon...supposed to go on the dyno Friday. I'll get a kit and have it ready.
capevette: Already checked the float level thanks! I also followed Lars paper...so Im all in (36 degrees by 2500 RPM). My hesitation (sputtering) comes in at 4500 RPM. Ummmm.
Old Jun 8, 2006 | 10:12 AM
capevettes's Avatar
capevettes
CF Community Team
2016 C2 of Year
OK, Now I'm thinking Wires, plugs, fuel filter, air filter. But you probably already checked that too.
Old Jun 8, 2006 | 11:25 AM
Muddywaters
Capevetts...all brand new here...
Old Jun 8, 2006 | 12:48 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Are you geting a bog at WOT or just some sputtering?
Old Jun 8, 2006 | 12:51 PM
Muddywaters
Dark Blue...I'd say a combination of the two...maybe more of a bog...
Old Jun 8, 2006 | 12:53 PM
Fevre's Avatar
Fevre
Unhook or wire the sec shut, if the car still cuts out it is not them
Old Jun 8, 2006 | 12:55 PM
Muddywaters
Ummm...thats an excellet idea...thanks!
Old Jun 8, 2006 | 01:40 PM
BigBlockk's Avatar
BigBlockk
Sounds like the secondaries are too lean.
BigBlockk
Later.....
To Secondaries not working right...
