Help me read these plugs!
Your float levels good?
Make sure your idle mix is spot on.
If so, try smaller primary jets,..though stock jetting on a 650 atop a 355 shouldn't be too rich.
The hesitation you speak is probably due a insuffecient pump shot from the accelerator pump,..try two sizes bigger accel. cam.
Laslty, a blown power valve will cause rich condition,..might check that.
Let us know what you find,..curious.
I had to richen the jets on my demon but lean out the squirters. Need more info... And if you have an idle eze, make sure that it is open all of the way.
I believe it's lean because I dropped the primary jets 8 sizes from stock (72 to 64). With the 72's it just ruined the entire plug in a few miles to the point where it would hardly run. I thought is was strange that half of the plug would be clean and the back part sooty. Plus I can't believe that I'd need to go smaller than 64 on the primary side.
The float level is near the bottom of the sight plug.
I was pretty careful setting the idle mixture for maximum vacuum and I made sure all 4 screws are equal.
I guess I should check the power valve, although it's a new carb.
I don't understand how the idle jets work. As far as I know the idle mixture is controlled by the mixture screws. What would I have to do to change those jets? I guess the bigger question is why would I need to. It seems like this carb SHOULD be a good match for this engine.
One other thing I'm not sure about is the idle eze valve. I messed with it a little when I first put the carb on, but nothing I did with it seemed to have any effect. I finally just closed it all the way. I figured it would only come into play on a more radical engine that had problems idling.
At this point, I think my problem is in the idle circuit. Maybe the plugs are loading up at idle and then partially cleaning up while cruising. Thus the half and half plug. This is my brother's car and he'll bring it over this weekend for some more fun!
Advancing the initial timing will help as will running manifold vacuum to your vacuum advance (not ported or timed vacuum). These two moves will increase your idle speed,..then you can reduce the idle at the carb which closes the primaries and covers the transition slots.
Or, some folks open the the secondaries a bit at idle which allows you to reduce opening of the primaries. There's an adjustment on the passenger's side of the secondary throttle shaft.
The above and checking for a blown power valve is where I'd start.
Lastly,..dropping the jets eight sizes is no bueno,..you're gonna burn a hole in a piston. Go back to stock and tune her two sizes either way. If it needs more or less, there's something wrong elsewhere.
You're rich in one of the circuits (idle, transistion, main, power),..just need to find out which one and why.
Good luck!
Lastly,..dropping the jets eight sizes is no bueno,..you're gonna burn a hole in a piston. Go back to stock and tune her two sizes either way. If it needs more or less than two sizes from stock, there's something wrong elsewhere.
Good luck!
