What goes down does not come up
Old Jun 9, 2006 | 08:35 AM
FIRST81VETTE's Avatar
FIRST81VETTE
Cruising
Default What goes down does not come up
I don't get it??? The window goes down, but does not come back up.
I have:
*Put 2 new motors in
*Put a new spring in (not sure if I did this right. it just slid in)
* Tested switch - pulled connction from motor. Put testlight on blue and pushed switch down and test light lights up. Put testlight on brown and pushed switch up and test light lights up.
I don't get it???????
Old Jun 9, 2006 | 09:07 AM
moosie982's Avatar
moosie982
I think that for the spring you installed to work it would need to be under tension,,give it a twist, BE CAREFUL ,, no action , no "help" if it just fell into place, I am sure that someone else can give ya more ideas as to why,,,Peace, Moosie
Old Jun 9, 2006 | 09:08 AM
SIXFOOTER's Avatar
SIXFOOTER
does the motor try to move the window up when you hit the button?
Old Jun 9, 2006 | 09:09 AM
SIXFOOTER's Avatar
SIXFOOTER
spring has to have a preload on it with the window UP and more of a preload when down
Old Jun 9, 2006 | 09:24 AM
sperkins's Avatar
sperkins
Sorry - wish I could help more. I have attached a picture of my power window set up for you.
Old Jun 9, 2006 | 10:08 AM
...Roger...'s Avatar
...Roger...
I have:
Test the connector. again when connected to motor -if on up it doesnt light it could a broken wire in the door -and still make enough connection to light when not under load.also try holding switch to up and wiggling wiring in between door and body.
Old Jun 9, 2006 | 10:12 AM
...Roger...
Yes this first if it does then the spring thingyor something in the way of the window a screw or something.Is the bolt to hold the arms in place while putting the spring in still installed?
Old Jun 9, 2006 | 12:07 PM
427-390's Avatar
427-390
ROTFLMAO!
Old Jun 9, 2006 | 02:24 PM
1Z87L8's Avatar
1Z87L8
is that one of those Taiwanese replacements?
To What goes down does not come up
