Cam Question
Old Jun 10, 2006 | 08:36 AM
OUT TO HAVE FUN's Avatar
OUT TO HAVE FUN
4th Gear
Default Cam Question
Have a 73 corvette 350 has 8.5 to1 pistons would like to put a comp cam in for better take off has .24 lift onintake&exhaust got 600 holly carb&ellenbrock highrise intake headers and sidepipes. What size cam can I put in and still run on the 95 octine gas and make my engine sound and act tuff.
Old Jun 10, 2006 | 12:13 PM
stingr69's Avatar
stingr69
268H Comp is an oldie but a goodie for that but might be a little tame. Should will get the job done.
Generaly with low compression it is difficult to put a big cam in there. If you want a lumpy idle and a higer narow torque curve you want to look for tighter lobe centers.
-Mark.
Old Jun 10, 2006 | 12:31 PM
painterman52's Avatar
painterman52
Thats the cam I was told yo use by a local engine builder, because of the low compression. Thats the he268h not the xe268h. I was pretty happy with it.
Old Jun 11, 2006 | 08:34 AM
OUT TO HAVE FUN
4th Gear
Thanks guys I will give the he268h comcam a try and let you know how it works plus people are telling me to put heaver valvesprings in or it will not work is this true.
Old Jun 11, 2006 | 08:45 AM
Ganey's Avatar
Ganey
You need to state trans. & rear gears for cam.
HE268H w/ 1.52 rockers is max. for stock valve springs.
Old Jun 11, 2006 | 11:55 AM
OUT TO HAVE FUN
4th Gear
Thanks for the advise I will let you know how it turns out
To Cam Question
