Difficult steering
Old Jun 11, 2006 | 04:43 PM
ohfiver's Avatar
ohfiver
Default Difficult steering
Replaced the power steering pump on my 72 "454" and the steering is difficult. Did the whole process per the service manual. Would air in the system be the cause of this problem? Any suggestions.
Old Jun 11, 2006 | 05:34 PM
wombvette's Avatar
wombvette
No, but a bad pump will.
Old Jun 11, 2006 | 06:13 PM
Duke94's Avatar
Duke94
Did it steer OK before you replaced the pump?
Old Jun 11, 2006 | 06:29 PM
jotto's Avatar
jotto
Define difficult for us....uniformly difficult, hard to turn wheel? Hard to turn one way but not the other? steering jumps to one side on startup etc etc..
Old Jun 11, 2006 | 06:30 PM
SmokinBBC's Avatar
SmokinBBC
Can you describe "difficult steering"....when you turn the wheel standing still at idle, does it feel like it is bouncing to the left and right? If so, you have air in the system....turn the wheel full left and let it sit overnight, that will get out any remaining air...
Old Jun 12, 2006 | 07:56 AM
mirrorfinishman's Avatar
mirrorfinishman
Did you replace your pump with an AC DElCO re-manufactured pump? or one from some other company?
Old Jun 12, 2006 | 11:35 PM
ohfiver's Avatar
ohfiver
Replaced with rebuilt from local auto zone. At idle the steering wheel drifs to the left. When moveing steering seems ok to the left but hard to turn to the right. Will try the suggestion on turn to left and let sit overnight. Thanks all!
Old Jun 12, 2006 | 11:41 PM
wombvette's Avatar
wombvette
Adjust the steering valve.
Old Jun 13, 2006 | 12:19 AM
lucky76's Avatar
lucky76
This is why it's drifting to the left. Rod must
be centered. Watch your face or head or hand when
doing this.
Old Jun 13, 2006 | 11:55 AM
ohfiver's Avatar
ohfiver
Thanks for the tip, will give it a try.
Old Jun 13, 2006 | 02:03 PM
mirrorfinishman
Replacing only the ps pump should not require adjusting the steering valve.
Personally, I would put the front end of the car up on jack stands and go thru the proper bleeding procedure of turning the steering wheel from lock to lock with the engine off.
Old Jun 13, 2006 | 02:44 PM
wombvette's Avatar
wombvette
I would agree that would seem to be the case, but his description of the problem does.
Old Jun 13, 2006 | 06:27 PM
SmokinBBC's Avatar
SmokinBBC
Bleeding is a must...but I don't think that air in the system would cause a drift while at idle...the only thing that could cause this in my opinion is the power steering control valve..and if it is the valve, then it must be way out of whack to be able to turn the wheels while the car is not moving.
Old Jun 13, 2006 | 10:13 PM
ohfiver's Avatar
ohfiver
Thank you all, will go back through the bleeding procedure per service manualand and see what happens.
Old Jun 13, 2006 | 11:10 PM
mandm1200's Avatar
mandm1200
There are plenty of threads about this. I don't think it's air and I'm not sure what is meant by bleeding; this isn't brakes. Check the fluid, it should not be foamy. If it is, let it settle so the air bubbles come out. Disconnect the steering cylinder from the frame. If the ram extends or retracts, the control valve must be balanced. Jim Shea, 'the expert', has enough documents to help anyone.
Jim, if you're reading this, that was a compliment. Everytime I sent a PM to Jim he responded promptly and was extremely knowledgeable. I even overpaid to get the GM power steering fluid (about $9 a quart) as recommended by Jim.
Old Jun 14, 2006 | 06:04 AM
mirrorfinishman
I recently installed a brand new GM ps control valve after dealing with a defective remanufactured valve for the past month. I also followed Jim's advice and went with GM ps fluid. The power steering now works perfectly.
To Difficult steering
