M22 4-Spd Advice Needed
Old Jun 11, 2006 | 06:37 PM
c3andc5's Avatar
c3andc5
Default M22 4-Spd Advice Needed
I have a 73 Coupe with the M22 4-spd tranny. Recently replaced the flywheel, clutch plate and disc with new parts. Since then I've had to replace the throw-out bearing three times. It makes a sort of whining/groaning sound when the clutch is fully depressed. I find it hard to believe that three new throw-out bearings are bad. Could a bent clutch fork be causing that? Any ideas?
Old Jun 11, 2006 | 08:14 PM
...Roger...'s Avatar
...Roger...
Yes a bent fork could do it and a finger or 2 staying in contact with the bearing could also do it.I assume you are leaving 1/2 inch freeeplay.
Old Jun 12, 2006 | 05:54 AM
c3andc5's Avatar
c3andc5
Yes on the freeplay. I'll have the fork looked at then. Thanks
To M22 4-Spd Advice Needed
