If I am reading it correctly your low A/F was 9.4 with the average being 10.3. This is EXTREMELY rich. Your A/F should be between 12.5:1 and 13.5:1 for maximum power.
You are leaving a good amount of power on the table.
Ya that thing is rich as sh*t. You need the AFR between 12.5-13.2 to 1 for the most power on a naturally aspirated motor. You are probably losing 20hp with the AFR in the 9-10 range. You need to tune that baby...
I would invest in a Air/Fuel meter such as DynoJet Wideband Commander or the LM-1 from Innovate Motorsports. I have both of these but prefer the DynoJet Wideband Commander due to the analog gauge as opposed to the digital readout of the LM-1.
The other thing to do would be to find someone with a DynoJet that might be persuaded to help you dial in your carburetor.
Steve
You can also get a digital gauge with log start button for the LM1. It has a digital AFR read out, along with a bar graph. It also has the button that you can activate the log with. Its about $250 though... it does plug right in to the LM1s analog channel
