q-jet CFM
Old Jun 12, 2006 | 06:19 PM
rottwild95's Avatar
rottwild95
Default q-jet CFM
I have a rochester off a '79 auto corvette on my '84 corvette.
not happy with the carbs performance and am trying to find the cfm's on the stock '79 vette carb so I can get an equal holley.
any help
Harry
Old Jun 12, 2006 | 06:50 PM
rcread's Avatar
rcread
The stock Q Jet is 750 cfm, which translates to a 600 cfm Holley. Your '84 should be fuel injected, of course. Rather than switch to a Holley, I would tune the Q Jet properly, or have it done if you aren't up to the task.
Old Jun 12, 2006 | 06:53 PM
Rydin Dirty's Avatar
Rydin Dirty
Old Jun 12, 2006 | 07:15 PM
enkeivette's Avatar
enkeivette
Why in the world did you give up FI for a Q-Jet? I could see putting a carb on a C4 if you were dropping in a potent stroker but then you wouldn't be using a Q-Jet.
Old Jun 12, 2006 | 08:31 PM
ajrothm's Avatar
ajrothm
Because 84 had the crap-fire injection... 85 was TPI. I would rather have a ratty *** q-junk then the crap-fire.
Old Jun 12, 2006 | 08:54 PM
a1sensei's Avatar
a1sensei
Wait till you get the Holley!
Old Jun 12, 2006 | 09:39 PM
Little Mouse's Avatar
Little Mouse
Can I make a suggestion if you are going to spend the money for a new
holley or demon, buy one that has anular boosters unless you are an all out RPM drag racer. Vacuum secondaries make sense for a street car,
every hi po engine chevy built with a holley had vacuum secondaries.
( yes the race motor L88 had a double pumper ) If you are going to have your car on the drag strip all the time get a double pumper.
( they drink a little more fuel and have more parts to screw up )
Demon has carbs in 750 to 850 cfm, anular boosters with vacuum secondaries or double pumper. Holley may have the same thing.
Old Jun 13, 2006 | 12:03 AM
694speed350's Avatar
694speed350
why is this on the c3 post? an 84 is a c4.
Old Jun 13, 2006 | 01:23 AM
Jclgodale3's Avatar
Jclgodale3
Cause it's C3 related
Old Jun 13, 2006 | 01:50 PM
Chilli's Avatar
Chilli
I wish I had a dime for every time I've run into someone who thinks they've GOT to have a double pumper regardless of whether or not the car will ever see the 1/4 mile. Even though I'll hit the track a few times each year, I'm goin' with the vac. sec. Fewer headaches.
Old Jun 13, 2006 | 01:56 PM
big_G's Avatar
big_G
Because the brains are in the C-3 forum....
Old Jun 13, 2006 | 02:22 PM
Kalway's Avatar
Kalway
My advice:
Fix the q-jet. A holley isn't going to solve your problems.
By the way, how's your timing? Like Lars says, that's what the majority of problems people attribute to carbs are.
Old Jun 13, 2006 | 02:29 PM
NHvette's Avatar
NHvette
Originally Posted by Kalway
My advice:
To q-jet CFM
