Power Steering Valve Adjustment
Well, i can't vouch for that method, (that is "tweaking it" while on its wheels) because I've not done it, and some might say you should get it back up the axle stands to do it again "by the book", but there's no reason why you shouldn't try it your way!
My logic on this is as follows:
It's turning harder to the left, which means there is more resistance to movement when the cylinder's *extending*. That to me would suggest that the valve is set up so the cylinder is on the verge of *retracting*, and that you therefore need to give the nut a slight *clockwise* turn, (given what you say about the clockwise turn acting to push the cylinder out - you've still got this fresh in your head from the service manual, I wouldn't have remembered it myself!)
That's based purely on my "logic" of how the system works, I've seen no actual documents on which direction of the screw affects which turn stroke....
After all, if you give it a quarter turn one way and it gets worse, give it a half turn the other and it should be bang on...
It sounds like something inside the control valve is not operating properly, causing there to be less resistance turning in one direction than the other.
